Get world position of MeshBody's MeshNode (Vertex)
Hello
I have a MeshBody and would like to find the World coordinate of its vertexes (nodes). Right now I am using Meshbody>mesh>nodeCoordinates but they seem to be relative to mesh origin.
How can I get the world-space coordinates?
kandennti
Hi n_autodesk.
I have written how to get Matrix3D for conversion here.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/incorrect-transformation-from-occurrence-t...
If you get Matrix3D from the component (occurrence) to which MeshBody belongs and
use transformBy method of nodeCoordinates (Point3D), you can get world-space coordinates.
I want to make it if I have time.
Awesome!
This almost works (or I have misunderstood how to implement it).
It works fine when I move the component, but when I move the body itself it no longer works since the function looks at the component and not at the mesh body. I hope this will be as simple as finding the occurrence for the mesh body and making it the first step.
kandennti
I tested it.
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des = app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        # select
        msg = 'select MeshBody'
        mb :adsk.fusion.MeshBody = selectMeshBodies(ui, msg)
        if not mb: return
        mat3d :adsk.core.Matrix3D =getRootMatrix(mb.parentComponent)
        # This is a clone
        # nodes = mb.mesh.nodeCoordinates #NG!
        nodes = mb.displayMesh.nodeCoordinates
        # transform
        [node.transformBy(mat3d) for node in nodes]
        # Create a sketch at the root and create a point
        skt = root.sketches.add(root.xYConstructionPlane)
        skt.isComputeDeferred = True
        [skt.sketchPoints.add(node) for node in nodes]
        skt.isComputeDeferred = False
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getRootMatrix(
    comp :adsk.fusion.Component) -> adsk.core.Matrix3D:
    comp = adsk.fusion.Component.cast(comp)
    des = adsk.fusion.Design.cast(comp.parentDesign)
    root = des.rootComponent
    mat = adsk.core.Matrix3D.create()
    if comp == root:
        return mat
    occs = root.allOccurrencesByComponent(comp)
    if len(occs) < 1:
        return mat
    occ = occs[0]
    occ_names = occ.fullPathName.split('+')
    occs = [root.allOccurrences.itemByName(name)
                for name in occ_names]
    mat3ds = [occ.transform for occ in occs]
    mat3ds.reverse() #important!!
    for mat3d in mat3ds:
        mat.transformBy(mat3d)
    return mat
def selectMeshBodies(
    ui :adsk.core.UserInterface,
    msg :str) -> adsk.fusion.MeshBody:
    filtterStr = 'MeshBodies'
    while True:
        try:
            sel :adsk.core.Selection = ui.selectEntity(msg, filtterStr)
            return sel.entity
        except:
            return None
This did not get the correct position.
Meshbody.mesh.nodeCoordinates
Movements that are not visible on the timeline appear to be ignored.
If it is here, I think that it can be processed correctly.
Meshbody.displayMesh.nodeCoordinates
please make sure.
Thank you, this works perfectly. I just hope the displayMesh will always be the same as the mesh, but I see no reason why that wouldnt be the case.
