Reading YAML from a Python Script
bloudraak
bloudraak
I have a YAML file that I'd like to use in a Python script to drive design in Fusion 360.  I rean
pip3 install pyyaml
But when running the script, you'll get an error yaml isn't found.
I understand that Fusion 360 uses its own version of python, and as such there are some challenges. But in all honesty, the beauty of using Python is the ability to use tens of thousands of packages out there that can add value to Fusion 360.  It would be rather disappointing if I'm unable to reference external packages, or if Fusion 360 discards changes to the environment after an upgrade.
Software Engineer
https://wernerstrydom.com
JeromeBriot
You have to execute pip3 in the Python folder of Fusion 360. To find its path, run the following script (taken from the addin Open folders) :
import os
directory = os.path.join(os.getenv('LOCALAPPDATA'), 'Autodesk', 'webdeploy', 'production')
fusion360Install = max([os.path.join(directory,d) for d in os.listdir(directory)], key=os.path.getctime)
print(os.path.join(fusion360Install, 'Python'))
Note that you have to reinstall the module each time Fusion 360 is updated.
Some other methods have been discussed recently: After Fusion 360 background update, I need to reinstall numpy . . . . . . .
bloudraak
Thanks. It's a bit disappointing. Is C++ support any better in that I can link with 3rd party libraries and not have to worry about updates breaking scripts or add-ins? I've only used Python scripts.
Software Engineer
JeromeBriot
Try this:
  1. Install pyyaml using pip3 as described previously
  2. Go to the "Python\Lib\site-packages" subfolder
  3. Copy the folder "yaml" into a subfolder "modules" in your add-in folder
  4. Uninstall pyyaml using pip3
  5. Call pyyaml by using the following inclusion:
from .modules import yaml
Now the module is independent from the Fusion 360 installation.
pludikar
@bloudraak
If you want to permanently attach a python library or extension to a script or Addin you are writing, then the only real way is to put the library/extension as a subfolder to your script folder.  It's briefly described here in the Fusion API user manual, but you'll have to scroll down to the appropriate section, as the page anchor is broken
If the library is more complex than a single folder, you may have to insert the appropriate folder path into syspath.
sys.path.insert(0, appPath+"\\py_packages_path")
I had to do that to include the pydantic extension, because there were inter package dependencies that couldn't be resolved using relative references.
If you just want to have the extension available just for development purposes then @JeromeBriot 's answer is the way to go.
Regards
Peter
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
