Python Add In Logging Window
mpieper
mpieper
What are the options for adding in a window with which I can log progress / output of python scripts?  I'm not seeing anything obvious in the userInterface API, but, alas, have not plumbed the depths.
Having a script / stdout window would be a huge boon to development on more complicated scripts.
kandennti
Hi @mpieper .
I use the TextCommands output palette.
def dumpMsg(msg :str):
    adsk.core.Application.get().userInterface.palettes.itemById('TextCommands').writeText(str(msg))
This is convenient because you can see the progress without leaving the GUI.
mpieper
Okay so that's getting me closer.
Direct pings to the function work.  I'd like to wrap it in a handler so I can just use logging like I normally would. e.g.
import logging
import adsk.core, adsk.fusion, adsk.cam, traceback
class Fusion360Handler(logging.Handler):
    def emit(self, record):
        msg = self.format(record)
def run(context):
    #Grab local logger (NOTE: Cannot put this out of function scope)
    logger = logging.getLogger(__name__)
    logger.setLevel(logging.DEBUG)
    #Instantiate handler, set level, and add to logger.
    handler = Fusion360Handler()
    handler.setLevel(logging.DEBUG)
    logger.addHandler(handler)
    logger.info("HELLO") #THIS FAILS
Here's a basic dumb sample script.  It's failing due to there being A LOT of extra loggers floating around with similar names / there seems to be multiple entries into the "run" function (e.g. enter into the function "run" multiple times)?  I pared it down a little further by forcing the logger to take a unique instance/name, and even then it bugs out on logger.info.
Line 1524, in handle  self.callHandlers(record)  File "C:\Users\mpiep\AppData\Local\Autodesk\webdeploy\production\c1a39fe96c80078ad566b938d0f03989f4b85b09\Python\lib\logging\__init__.py", line 1585, in callHandlers  if record.levelno >= hdlr.level: AttributeError: type object 'Fusion360Handler' has no attribute 'level'
Despite me looking at the handler directly and confirming it does in fact have a level attribute.  I have not looked under the covers to see how these scripts are patched in....
JesusFreke
You might take a look at my fusion add-in for intellij IDEA. It wraps stdout, so anything you log in the add-in goes to the terminal in IDEA. It's pretty convenient during development! But it does involve setting up a completely separate development environment (IDEA instead of VSCode), so maybe not worth it if you just want logging.
