Problem with Deleting Attributes
Hello. I have a problem with deleting attributes. I create custom class. It contain a list of BrepFaces Objetcs inside. I add to face an attribute, then i add this face to the list of faces. If i delete attribute from face from list later, brepFace in model still contains this attribut, but face in list - not. Why it occurs?
Python code:
add attribute function:
def setAttributeToFaceInModelByName ( pFace, pName):
    retCode=checkEFAttributes(pFace)
    if retCode != EFErrorNotFindAttributes: return retCode
    pFace.attributes.add(EFAttributeGroupName,pName,'1')
    return EFIsOK
Remove attributes function:
def removeEFAttributes(pFace):
    retCode=checkBrepface(pFace)
    if retCode != EFIsOK: return retCode
    if pFace.attributes.itemsByGroup(EFAttributeGroupName):
        attributes = pFace.attributes.itemsByGroup(EFAttributeGroupName)
        for pAttib in attributes:
            pAttib.deleteMe()
    return EFIsOK
liujac
I can’t reproduce the problem with the script below. Could you provide more info? How do you get the faces? That would be better if you can provide the runnable script and the model file.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        face = design.rootComponent.bRepBodies[0].faces[0]
        face.attributes.add("GroupName", "Name", '1')
        ui.messageBox("face.attributes.count: " + str(face.attributes.count))
        attributes = face.attributes.itemsByGroup("GroupName")
        for attrib in attributes:
            attrib.deleteMe()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Jack
I try add or delete Attributes in CommandInputChangedHandler (adsk.core.InputChangedEventHandler), when i click button "add" or "delete".
Attributes add or delete to faces succesfully. I check it in console. If I close CommandInput window, changes is missing. Faces not get new Attributes or not delete old Attributes.
liujac
I recommend you make the changes in Execute event. We only commit the changes made in Execute event. The changes made in other command events like InputChanged event just are preview and aborted right away.
For more information about Fusion Commands, please read http://fusion360.autodesk.com/learning/learning.html?guid=GUID-3922697A-7BF1-4799-9A5B-C8539DF57051.
Jack
Thank you. It work in Execute event.
