How to save as STL on iMac
im using Fuson 360 on an iMac and need to save it as an stl on my usb. Othere answrs for this have said to select all bodies then right click but mine just selects the face, axis or line the mouse is on or if i click off the object it just deselects all. The same happens with left clicking.
Thanks 🙂
The first picture is all selcted and the second, what happens when i right or left hand click the design or grid
marshaltu
I would get more information to narrow the issue down:
1. Were you seeing the behaviour for all designs or only specific designs?
    If it is dataset specific issue, it would be great if you can send me(marshal dot tu at autodesk dot com) a copy of your design or invite me(the same email address) into your project for a look.
2. Please check if "Selection Filters"(toolbar panel -> SELECT) is set correctly. By default, all filters will be checked.
3. I am not sure how you select all. You could find root item in browser and just right-mouse click on it and invoke "Save as STL".
Marshal
Marshal Tu
Fusion Developer
