Turning off history capture prevents code execution
A small snippet of my code is below which creates a shell and then a tangent plane on it's outer edge. The code then undergoes a lot of iterations and so I would like to turn history capture off to improve performence, however when I disable history capture, a plane through the centre of the extrusion occurs. Why does history capture affect execution of the code?
import adsk.core, adsk.fusion, adsk.cam, traceback def run(context): ui = None #Get application app = adsk.core.Application.get() #Get application ui ui = app.userInterface #Get open design (open document) design = app.activeProduct #Get root component. root = design.rootComponent #Get sketches sketches = root.sketches #Delete all sketches and features first. print('sketches count', root.sketches.count) for i in range(root.sketches.count): print('Success:', root.sketches.item(i).deleteMe()) for i in range(root.features.count): print('Success:', root.features.item(i).deleteMe()) for i in range(root.constructionPlanes.count): print('Success:', root.constructionPlanes.item(i).deleteMe()) #Get XY sketches. sketchXZ = root.sketches.add(root.xZConstructionPlane); cyl_H = 20 cyl_R = 5 cyl_thickness = 0.4 cyl_r = cyl_R - cyl_thickness #Draw big cylinder. circles = sketchXZ.sketchCurves.sketchCircles circles.addByCenterRadius(adsk.core.Point3D.create(0,0,0),cyl_R) circles.addByCenterRadius(adsk.core.Point3D.create(0,0,0),cyl_r) #Go through and get the profile with the smallest area. profiles = sketchXZ.profiles if(profiles.item(0).areaProperties().area > profiles.item(1).areaProperties().area): cylProfile = profiles.item(1) else: cylProfile = profiles.item(0) #Extrude this profile. extrudes = root.features.extrudeFeatures extInput = extrudes.createInput(cylProfile, adsk.fusion.FeatureOperations.JoinFeatureOperation) distance = adsk.core.ValueInput.createByReal(cyl_H) extInput.setDistanceExtent(False, distance) cylExtrude = extrudes.add(extInput) print('Cylinder Extruded') #Get the external face (bigger area) cylOutsideFace = cylExtrude.sideFaces.item(0) if(cylExtrude.sideFaces.item(0).area < cylExtrude.sideFaces.item(1).area): cylOutsideFace = cylExtrude.sideFaces.item(1) print('Got outside face') #Get planes. planes = root.constructionPlanes print('planes = root.constructionPlanes') planeInput = planes.createInput() print('planeInput = planes.createInput()') angle = adsk.core.ValueInput.createByString('0 deg') print('angle = adsk.core.ValueInput.createByString(0 deg)') planeInput.setByTangent(cylOutsideFace, angle, cylProfile) print('planeInput.setByTangent(cylOutsideFace, angle, cylProfile)') tangentPlane = planes.add(planeInput) print('tangentPlane = planes.add(planeInput)')
