Previous working API Python script now fails at Project Body Projection Link
info83PHN
info83PHN
I have a python API script I wrote about a year ago ( around 3 or 4 Fusion updates ago ).
It was working perfectly at the time.
Now it fails when I try and Project existing Bodies to a new Sketch.
It appears that the script is executing the Project Body with the 'Projection Link' turned OFF.
If I create the Body Projections manually with 'Projection Link' turned ON, then the result is exactly as I need it to be.
Is it possible to set the 'Projection Link' to ON within a Script ?
                # create a sketch for the border shape
                # create sketch on the 'TextPlane' plane
                uTextPlane = rootComp.constructionPlanes.itemByName('TextPlane')
                sketches = rootComp.sketches
                sketch = sketches.add(uTextPlane)
                sketch.name = 'Border'
                projectedSketchEntities = []
                for body in inputColl:
                    projectedEntities = sketch.project(body)
                    projectedSketchEntities.extend([e for e in projectedEntities])
kandennti
Hi @info83PHN .
I tried it and saw that the link was indeed broken. I think it is probably a bug.
The screen moves, but I made a sample using text commands as an alternative.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        rootComp: adsk.fusion.Component = des.rootComponent
        projectedEntities = projectBodies(sketch, rootComp.bRepBodies)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def projectBodies(
    skt: adsk.fusion.Sketch,
    bodies: list) -> list:
    tokens = [c.entityToken for c in skt.sketchCurves]
    tokens.extend([p.entityToken for p in skt.sketchPoints])
    sels: adsk.core.Selections = app.userInterface.activeSelections
    sels.clear()
    sels.add(skt)
    app.executeTextCommand(u'Commands.Start SketchActivate')
    sels.clear()
    app.executeTextCommand(u'Commands.Start ProjectNewCmd')
    app.executeTextCommand(u'Commands.SetString infoFilterType {}'.format('infoFilterTypeBodies'))
    [sels.add(body) for body in bodies]
    app.executeTextCommand(u'NuCommands.CommitCmd')
    app.executeTextCommand(u'Commands.Start SketchStop')
    projectedEntities = [c for c in skt.sketchCurves if not c.entityToken in tokens]
    projectedEntities.extend([p for p in skt.sketchPoints if not p.entityToken in tokens])
    return projectedEntities
BrianEkins
I can reproduce this and confirm it is a bug. Hopefully, it can be fixed soon.
Brian Ekins
info83PHN
Many Thanks
Do we need to report this bug somewhere to get it corrected ?
I am wasting hours with having to manually do the projections manually
BrianEkins
Autodesk is aware of the problem, thanks to you reporting it, and are looking into it.
Brian Ekins
BrianEkins
It looks like this has been fixed in the latest update.
Brian Ekins
