Cannot change multiple joint origin properties
Skullivan
Skullivan
I'm having a weird problem where I have created a joint origin and immediately after I am trying to set isFlipped to True and give it an x-axis entity. The problem is that it will only change the first parameter in the code.
For example:
This code will only make the joint origin flipped and will not give it an xAxisEntity.
        pringle_factory_origin.timelineObject.rollTo(True)
        pringle_factory_origin.xAxisEntity = axis_selection
        pringle_factory_origin.isFlipped = True
        design.timeline.moveToEnd()
This code will only give the joint origin an xAxisEntity but will not be flipped.
I also tried using the rollTo() method before each parameter change and still it only changes the first parameter in the program. It seems to be resetting the first parameter that I try to change when the second parameter gets set.
Anyone have any ideas? Am I missing something obvious here?
kandennti
Hi @Skullivan .
I tried it.
I was able to confirm that the first process is indeed cleared.
Probably a bug.
The attached data is on the left side, and the API of Ver2.0.14110 does not allow me to change it to the right side.
I forced myself to create a sample to be processed by text command.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        design: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = design.rootComponent
        pringle_factory_origin: adsk.fusion.JointOrigin = root.jointOrgins[0]
        sels: adsk.core.Selections = app.userInterface.activeSelections
        sels.clear()
        sels.add(pringle_factory_origin)
        app.executeTextCommand(u'Commands.Start EditJointOriginR2Cmd')
        app.executeTextCommand(u'Commands.SetBool Flip11 1')
        app.executeTextCommand(u'Commands.SetBool Reorient11 1')
        app.executeTextCommand(u'UI.EnableCommandInput XAxis11')
        sels.clear()
        sels.add(root.yConstructionAxis)
        app.executeTextCommand(u'NuCommands.CommitCmd')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
However, since it is necessary to separate the processing while checking the status, it will not be very useful.
Skullivan
So you're saying that I can process just one of the commands I'm losing as a text command and that should work as a workaround for now?
I did run your code and saw that it works this way. I just don't know enough to understand if this will work in line with the api methods I was trying to use.
It definitely would be good to see this bug fixed however.
BrianEkins
I can reproduce the problem you're seeing. I'll work with Autodesk to make sure a bug is filed and hopefully, it can be addressed soon.
Brian Ekins
