06:36 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Everyone,
I'm very new to python and scripting, and I have a goal. I want to create a surface loft, using 2 sketches. Later on, I want to create more complex things, but I'm unable to make the loft, and I have no idea why. Can someone tell me what I'm doing wrong and why?
Here's what the end result should look like:
Here's my code:
import adsk.core, adsk.fusion
app = adsk.core.Application.get()
ui = app.userInterface
design = app.activeProduct
# Get the root component of the active design.
rootComp = design.rootComponent
# Create a new sketch on the xy plane.
sketches = rootComp.sketches
xyPlane = rootComp.xYConstructionPlane
sketch = sketches.add(xyPlane)
# Create an object collection for the points.
points = adsk.core.ObjectCollection.create()
Steps = 10 #How many fibonacci steps to go through
R = Steps - 2
points.add(adsk.core.Point3D.create(0, 0, 0)) # This plots the origin
Bin1 = range(0, R, 2)
Bin2 = range(1, R, 2)
xCoord = 0
yCoord = 0
hossz = 1
for i in range(R):
if i in Bin1:
xCoord = xCoord
yCoord = yCoord + hossz
points.add(adsk.core.Point3D.create(xCoord, yCoord, 0))
if i in Bin2:
xCoord = xCoord + hossz
yCoord = yCoord
# Create the spline.
spline1 = sketch.sketchCurves.sketchFittedSplines.add(points)
#create second sketch
planes = rootComp.constructionPlanes
#### # Create construction plane input
planeInput = planes.createInput()
# Add construction plane by offset
offsetValue = adsk.core.ValueInput.createByReal(5.0)
planeInput.setByOffset(rootComp.xYConstructionPlane, offsetValue)
planeOne = planes.add(planeInput)
sketch2 = rootComp.sketches
offsetplane = planeOne
sketch = sketch2.add(offsetplane)
lines = sketch.sketchCurves.sketchLines;
line1 = lines.addByTwoPoints(adsk.core.Point3D.create(0, 0, 0), adsk.core.Point3D.create(4, 4, 0))
########LOFT
openProfile1 = rootComp.createOpenProfile(spline1)
openProfile2 = rootComp.createOpenProfile(line1)
# Create loft feature input
loftFeats = rootComp.features.loftFeatures
loftInput = loftFeats.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
loftSectionsObj = loftInput.loftSections
loftSectionsObj.add(openProfile1)
loftSectionsObj.add(openProfile2)
loftInput.isSolid = False
loftFeats.add(loftInput)Thanks in advance!
