No module named 'adsk' problem - Python script for Autodesk Fusion 360
I want to draw 3D spheres using x,y,z coordinate. Then I am trying to use Python script for Autodesk Fusion 360(CAD).
However, the error has oc
curred as the image. "No module named 'adsk' problem".
I tried to install the adsk module, but I cant intall.
Then I found that the adsk is in definition folder. So I tried to run the file. But I cant get result.
I have attached error image and my code.
hpekristiansen
- Go to Fusion 360 -> TOOLS -> ADD-INS -> Scripts and Add-Ins...
- Press Create
- Select script
- Press Edit
- Edit script in VS code
- Select script
- Press Run
How to enable breakpoints when debugging?
Moh_Samy
have you managed to know ?
scottmoyse
This has kept happening to me recently... then I noticed it was because the python interpreter kept changing in my IDE (in my case VS Code). It kept switching to v3.7.6 for some reason. As soon as I switched back to v3.7.3 it was fine.
Scott Moyse
Did your question get successfully answered? Please accept the post as a Solution to help others find it.
CAM Consultant and owner at Nominal Systems. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Moh_Samy
Great,
it worked for me as soon as i switched to Python 3.7.6 and added the (adsk.core) path to widows Environment Variables paths.
JeffBradway
In case anyone else is still struggling with this, here's some things that I did to get going:
Open VSCode and on the left click the Extensions icon, right click Python and Install Another Version. Then find version 2019.9.24911. Close VSCode. Restart Fusion 360 (if running).
Edit your Windows environmental variable for PATH. (Right click This PC>Properties>Advanced System Settings>Advanced>Environmental Variables.)  Under System Variables find Path and click Edit. Click New and add new lines for your Fusion Python folder and your Python install (if different)
C:\Users\<username>\AppData\Roming\Autodesk\Autodesk Fusion 360\API\Python\defs\
Restart your PC for good measure.
Launch Fusion. Open the Tools>Scripts and add-ons. Either create a new script or edit an existing one. VSCode should open.
To Debug: In VSCode click Run>Start Debugging
If you just try to hit the play button in the upper right of the script window then you will get the error. If you start the debugger then it should work.
Also, in the lower left of the status bar in VSCode it should say your Python version. Click on it. You will then be able to choose other interpreter versions that are installed on your PC. Pick the version with Autodesk in the path.
