My first add-in: Visual Styles
pawelzwronek
Message 1 of 100
pawelzwronek
Hello everybody.
Today i want to share with you my first addin I have created couple days ago. Because my previous idea of "Customized bottom navigation bar" gained whole 10 kudos i decided to write some kind of substitute of this idea. Fell free to download and test it because it's free 🙂 Below screenshot and link to appstore.
MAC and PC
What it does?
Simply a couple of buttons to quickly change visual style of active viewport.
Want to contribute?
Visit github.com/pawelzwronek/fusion360-VisualStyles
P.S. If you like it (or not) and use it please leave a comment in App Store to give me motivation to make it better or to write next one.
Replies (99)
Message 81 of 100
goran_G
It doesn't work on my Mac, probably some permissions problem. Will wait for the installer and see.
Update: I opened the old installer with Suspicious Package and modify the VisualStyles.py file by opening it and copy paste the contents from the new one and then installed it, but with no luck.
Message 82 of 100
bradley.selph
It works now after following your instructions. Thanks for the help!!!
Message 83 of 100
Works great now, thanks for the manual update.
Message 84 of 100
sleeperbu
Observer
Observer
I did this exactly and it didn't work. No visual styles setup between visual style and mesh display. I'd love to get it back. Disappeared after the most recent update September 2019.
Message 85 of 100
goran_G
Do you have a Mac or Windows PC? For me on a Mac it doesn't work, but for two other users it works, I don't know in what environment they work.
Message 86 of 100
bradley.selph
It works for PC!
Message 87 of 100
thelastsaxon
oh there is a god!
thankyou, was missing VS soo much you software god you!
Message 88 of 100
sleeperbu
Observer
Observer
I have pc windows 10
Message 89 of 100
sleeperbu
Observer
Observer
All is well. I'm a little slow but got it to work now. Thanks all.
Message 90 of 100
goran_G
The newly released installer version 1.2.3 (10/1/2019) does not work for me on Fusion 360 2.0.6508 and MacOS 10.14.6.
Message 91 of 100
Fueler
I am experiencing the same issue. Somewhere in the last 3 updates it quite being compatible.
I had started a thread on it before I found this thread.
https://forums.autodesk.com/t5/fusion-360-design-validate/visual-styles-problem/td-p/9117481
Thanks for looking into this.
I miss my Visuals.
Message 92 of 100
Weird it's working for me 😉 even after reinstall. Maybe try to uninstall it, manually remove folder C:\Users\<YOUR USER NAME>\AppData\Roaming\Autodesk\ApplicationPlugins\VisualStyles.bundle  and install it again. Remember not to launch F360 while doing this.
Also update to lastest F360, mine is 2.0.6613
Message 93 of 100
goran_G
Do you have a PC or Mac? Have you installed the last version 1.2.3?
Message 94 of 100
pawelzwronek
PC, I'm the author 🙂
Message 95 of 100
@goran_G
Thanks for your plugin, took me a while to find it but very happy with it now.
I hoped there would be a built-in possibilty to 'short-cut' the
Object- visibilty->All work features sequence
(see attached image)
Do you think your plugin could be adapted so that switching from 'all features' to 'no features' will become a lot easier? I added this idea to the ideastation a couple of months ago, but no response on it. https://forums.autodesk.com/t5/fusion-360-ideastation/shortcut-for-display-setting-gt-object-visibil...
Message 96 of 100
laughingcreek
This is an excellent idea.
wish there was a master switch for toggling all profiles and dims also, instead of having to go through sketches  individually.
Message 97 of 100
laughingcreek
@pawelzwronek -I can't seem to get visual styles to run on my win 10 pc.  I think I've tryed all the typical stuff (uninstall, restart, makesure fusion isn't running, run install, start fusion) it shows up in this directory-
C:\Users\my name\AppData\Roaming\Autodesk\ApplicationPlugins\VisualStyles.bundle
but it's not in the add-ins list.
 Do you have any suggestions?
Message 98 of 100
knndnnr
Love Visual styles! Works perfect on my Windows 10 F360 system. I bought a M1 Mac Mini, after hearing that Fusion runs nice and fast on the new Apple chip. It does! Much better than on the Window workstation. BUT, I have never gotten Visual Styles to install, ever, on my Mac. I run the script, like the instructions explain, and nothing happens.
I find working without it significantly harder. Can anyone explain what could be happening?
Message 99 of 100
knndnnr
Figured it out. Is there a shame-face emoji?
Message 100 of 100
motopreserve
Do tell. Might help the next folks having the same issue.
