My api scripts were missing after update to 2.0.1516 (mac)
funstea
Alumni Alumni
funstea
I was able to resolve my missing api scripts with the following Terminal command, hope this helps mac users.
rsync -av ~/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application\ Support/Autodesk/Autodesk\ Fusion\ 360/API/Scripts/ ~/Library/Application\ Support/Autodesk/Autodesk\ Fusion\ 360/API/Scripts/
Then restart Fusion.
zhijie.li
Hi funstea, The API scripts have different paths between Mac App Store version and Download version of Fusion 360. From your description, it probably has two kind of version installed on your machine. As you see, the API scripts will be loaded and managed in path “~/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application\ Support/Autodesk/Autodesk\ Fusion\ 360/API/” on Mac App Store version, and “~/Library/Application\ Support/Autodesk/Autodesk\ Fusion\ 360/API/Scripts/” on Download version. Best regards, Zhijie
