Can you place the center of a sketch circle with absolute coordinates?
MichaelAubry
Autodesk Autodesk
Message 1 of 9
MichaelAubry
Hi! I'm continuing to work on my fibonacci lofted path.  I've hit a snag with my sketch profile placement.  My sketches aren't lining up correctly. The root of the problem is my sketch plane tilts such that it isn't in line with the original orientation. This is becuase it's created from a plane along a path from a spline.  I'd like my circles to line up coincident with the endpoints of my spline.
Is there a way to place a circle inside a sketch using absolute coordanates for the center point?
Thank you!
Here's my code:
import adsk.core, adsk.fusion
app= adsk.core.Application.get()
design = app.activeProduct
ui = app.userInterface
#**Default User Inputs**
steps = "5 cm" #How many steps of Fibonacci would you like to plot?
#(Note, while the steps variable should be unitless, right now our API can't handle unitless number.
#cm are the absolute units we use on the API side.)
length = "3 cm" #How long is the first segment? (cm)
input = steps
createInput = ui.inputBox('Enter Steps', 'Steps', input)
if createInput[0]:
(input, isCancelled) = createInput
unitsMgr = design.unitsManager
realSteps = unitsMgr.evaluateExpression(input, unitsMgr.defaultLengthUnits)
input = length
createInput = ui.inputBox('Enter Length', 'Length', input)
if createInput[0]:
realLength = unitsMgr.evaluateExpression(input, unitsMgr.defaultLengthUnits)
#Get root component
rootComp = design.rootComponent
#Create a new sketch on XY plane
sketch = rootComp.sketches.add(rootComp.xYConstructionPlane)
# Create an object collection for the points.
points = adsk.core.ObjectCollection.create()
# R = total steps to be run thru the For loop
R = int(realSteps - 2)
#starting x and y coordiantes
x = 0
y = 0
#Create 1st coordinate
points.add(adsk.core.Point3D.create(x,y,0))
#Starting Loft Profile Diameter
loftProfile1 = realLength/2
#starting values for sequence
fib = 1
fib1 = 1
#Create 2nd coordinate
x = 1 * realLength
ui.messageBox('x: ' + str(x))
#bins for shifting x and y coordinates
Bin1 = range(0,R,4)
Bin2 = range(1,R,4)
Bin3 = range(2,R,4)
Bin4 = range(3,R,4)
BinLoft = range(0,R)
for i in range(R):
fib2 = fib + fib1
fib = fib1
fib1 = fib2
fibLength = fib*realLength #adds the scalar component to coordinates
ui.messageBox('fiblength: ' + str(fibLength))
if i in Bin1:
x = x
y = y + fibLength
if i in Bin2:
x = x - fibLength
y = y
if i in Bin3:
x = x
y = y - fibLength
if i in Bin4:
x = x + fibLength
y = y
if i in BinLoft:
loftProfile2 = fibLength/2 #Ending Loft Profile Diameter
# Create the spline.
sketch.sketchCurves.sketchFittedSplines.add(points)
# Create the Starting Loft Profile
spline1 = sketch.sketchCurves.sketchFittedSplines.item(0)
planeInput = rootComp.constructionPlanes.createInput() # you could also specify the occurrence in the parameter list
planeInput.setByDistanceOnPath(spline1, adsk.core.ValueInput.createByReal(0))
plane1 = rootComp.constructionPlanes.add(planeInput)
sketch1 = rootComp.sketches.add(plane1)
circles = sketch1.sketchCurves.sketchCircles
circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), loftProfile1)
# Create the End Loft Profile
# (This is the part that's giving me trouble)
planeInput.setByDistanceOnPath(spline1, adsk.core.ValueInput.createByReal(1))
plane2 = rootComp.constructionPlanes.add(planeInput)
sketch2 = rootComp.sketches.add(plane2)
circles = sketch2.sketchCurves.sketchCircles
circle2 = circles.addByCenterRadius(adsk.core.Point3D.create(0,0,0), loftProfile2)
Michael Aubry
Autodesk Fusion 360 Evangelist
Replies (8)
Message 2 of 9
casey.rogers
Hey Mike,
It should be an easier approach to simply apply a coincident constraint between a project of the spline's point and the center point of the circle, exactly the same as if you were creating the design using the GUI and not the API. If you feed a point3D object into the addByCenterRadius function (as you have in your script) the API will create a circle at that point but will not create any coincident constraints. However, if you use addByCenterRadius on a sketchPoint, the API (IIRC) will automatically create a coincident constraint between your circle's center point and the sketchPoint. The code to acheive this would look roughly like this:
centerPoint = sketch2.project(spline1.endSketchPoint)
circle2 = circles.addByCenterRadius(centerPoint, loftProfile2)
You can also manually create the coincident constraint, but I don't expect you to need to. Let me know if the above strategy does not work.
If you're not sure whether or not you should be projecting the endSketchPoint or the startSketchPoint of the spline, there are a couple ways to go about it, and probably at least one more elegant than what I'm about to suggest, but here is how I'd do that:
def isPointOnPlaneHelper(sketch, point):
    sp = sketch.project(point)
    if sp.geometry.isEqualTo(point):
        return sp
    else:
        sp.deleteMe()
        return None
Essentially, I'm testing if a point is on a sketch's plane. If it isn't, return None. If it is, return a sketchPoint created by projecting that point onto the sketch. You may find that in the context of your script you can reliably use the startSketchPoint or endSketchPoint depending on the context, in which case the above isn't necessary.
Message 3 of 9
ekinsb
I would suggest using the Sketch.modelToSketchSpace method.  You can pass in a point in model space and it will return the equivalent point in sketch space which you can then use as the coordinates for the circle center point.
Brian Ekins
Mod the Machine blog
Message 4 of 9
MichaelAubry
Thanks Casey,
The code you suggested is importing and projecting the the spline point but it isn't creating the circle. Is this the correct syntax?
Michael Aubry
Message 5 of 9
MichaelAubry
Thanks Brian,
Do you have an example using Sketch.modelToSketchSpace?  I'm having trouble figuring out how to make it work.
Thanks!
Mike
Michael Aubry
Message 6 of 9
casey.rogers
Yes, as far as I can tell that code should work!
Message 7 of 9
ekinsb
Here's the new last four lines of your program with my changes highlighted..
            skPosition = sketch2.modelToSketchSpace(spline1.endSketchPoint.geometry)
            circle2 = circles.addByCenterRadius(skPosition, loftProfile2)
Brian Ekins
Message 8 of 9
MichaelAubry
Brian thanks a bunch! That works perfectly. The .geometry part was something I neglected.  Thanks!
Mike
Michael Aubry
Message 9 of 9
eric.d.vaughan.account
Observer
Observer
I am trying to do something very simular. I want to create lofted tubes that curve in spirals. Would it be possible to see the code that actually does the loft?
