- Mute
- Permalink
- Report
Hi! I'm continuing to work on my fibonacci lofted path. I've hit a snag with my sketch profile placement. My sketches aren't lining up correctly. The root of the problem is my sketch plane tilts such that it isn't in line with the original orientation. This is becuase it's created from a plane along a path from a spline. I'd like my circles to line up coincident with the endpoints of my spline.
Is there a way to place a circle inside a sketch using absolute coordanates for the center point?
Thank you!
Here's my code:
import adsk.core, adsk.fusion
app= adsk.core.Application.get()
design = app.activeProduct
ui = app.userInterface
#**Default User Inputs**
steps = "5 cm" #How many steps of Fibonacci would you like to plot?
#(Note, while the steps variable should be unitless, right now our API can't handle unitless number.
#cm are the absolute units we use on the API side.)
length = "3 cm" #How long is the first segment? (cm)
input = steps
createInput = ui.inputBox('Enter Steps', 'Steps', input)
if createInput[0]:
(input, isCancelled) = createInput
unitsMgr = design.unitsManager
realSteps = unitsMgr.evaluateExpression(input, unitsMgr.defaultLengthUnits)
input = length
createInput = ui.inputBox('Enter Length', 'Length', input)
if createInput[0]:
realLength = unitsMgr.evaluateExpression(input, unitsMgr.defaultLengthUnits)
#Get root component
rootComp = design.rootComponent
#Create a new sketch on XY plane
sketch = rootComp.sketches.add(rootComp.xYConstructionPlane)
# Create an object collection for the points.
points = adsk.core.ObjectCollection.create()
# R = total steps to be run thru the For loop
R = int(realSteps - 2)
#starting x and y coordiantes
x = 0
y = 0
#Create 1st coordinate
points.add(adsk.core.Point3D.create(x,y,0))
#Starting Loft Profile Diameter
loftProfile1 = realLength/2
#starting values for sequence
fib = 1
fib1 = 1
#Create 2nd coordinate
x = 1 * realLength
ui.messageBox('x: ' + str(x))
#bins for shifting x and y coordinates
Bin1 = range(0,R,4)
Bin2 = range(1,R,4)
Bin3 = range(2,R,4)
Bin4 = range(3,R,4)
BinLoft = range(0,R)
for i in range(R):
fib2 = fib + fib1
fib = fib1
fib1 = fib2
fibLength = fib*realLength #adds the scalar component to coordinates
ui.messageBox('fiblength: ' + str(fibLength))
if i in Bin1:
x = x
y = y + fibLength
if i in Bin2:
x = x - fibLength
y = y
if i in Bin3:
x = x
y = y - fibLength
if i in Bin4:
x = x + fibLength
y = y
if i in BinLoft:
loftProfile2 = fibLength/2 #Ending Loft Profile Diameter
# Create the spline.
sketch.sketchCurves.sketchFittedSplines.add(points)
# Create the Starting Loft Profile
spline1 = sketch.sketchCurves.sketchFittedSplines.item(0)
planeInput = rootComp.constructionPlanes.createInput() # you could also specify the occurrence in the parameter list
planeInput.setByDistanceOnPath(spline1, adsk.core.ValueInput.createByReal(0))
plane1 = rootComp.constructionPlanes.add(planeInput)
sketch1 = rootComp.sketches.add(plane1)
circles = sketch1.sketchCurves.sketchCircles
circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, 0, 0), loftProfile1)
# Create the End Loft Profile
# (This is the part that's giving me trouble)
planeInput.setByDistanceOnPath(spline1, adsk.core.ValueInput.createByReal(1))
plane2 = rootComp.constructionPlanes.add(planeInput)
sketch2 = rootComp.sketches.add(plane2)
circles = sketch2.sketchCurves.sketchCircles
circle2 = circles.addByCenterRadius(adsk.core.Point3D.create(0,0,0), loftProfile2)
Autodesk Fusion 360 Evangelist
