Multiple UI Inputs on a single Row
JohnBuehler
JohnBuehler
Is it possible to format UI components to place multiple inputs on a single row such as 2 or more dropdowns or value inputs such as this graphic?
If not, can this be accomplished via Pallettes?
Thanks in advance.
kandennti
Hi @JohnBuehler .
This is possible with TableCommandInput Object.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-C3F746B3-6488-4B74-A441-31AFDEFD1648
You can find a sample here.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-e5c4dbe8-ee48-11e4-9823-f8b156d7cd97
Due to the large volume of the sample, this is what it looks like if you only use the part that relates to TableCommandInput.
#FusionAPI_python Script
import adsk.core, adsk.fusion, traceback
_app = adsk.core.Application.cast(None)
_ui  = adsk.core.UserInterface.cast(None)
# command Info
_cmdInfo = ['test', 'test', 'test']
_handlers = []
_rowNumber = 0
def addRowToTable(tableInput):
    global _rowNumber
    # Get the CommandInputs object associated with the parent command.
    cmdInputs = adsk.core.CommandInputs.cast(tableInput.commandInputs)
    # Create three new command inputs.
    valueInput = cmdInputs.addValueInput('TableInput_value{}'.format(_rowNumber), 'Value', 'cm', adsk.core.ValueInput.createByReal(_rowNumber))
    stringInput =  cmdInputs.addStringValueInput('TableInput_string{}'.format(_rowNumber), 'String', str(_rowNumber))
    spinnerInput = cmdInputs.addIntegerSpinnerCommandInput('spinnerInt{}'.format(_rowNumber), 'Integer Spinner', 0 , 100 , 2, int(_rowNumber))
    # Add the inputs to the table.
    row = tableInput.rowCount
    tableInput.addCommandInput(valueInput, row, 0)
    tableInput.addCommandInput(stringInput, row, 1)
    tableInput.addCommandInput(spinnerInput, row, 2)
    # Increment a counter used to make each row unique.
    _rowNumber = _rowNumber + 1
# Event handler that reacts to any changes the user makes to any of the command inputs.
class MyCommandInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            eventArgs = adsk.core.InputChangedEventArgs.cast(args)
            inputs = eventArgs.inputs
            cmdInput = eventArgs.input
            # table input Click Button Event
            tableInput = inputs.itemById('table')
            if cmdInput.id == 'tableAdd':
            elif cmdInput.id == 'tableDelete':
                if tableInput.selectedRow == -1:
                    _ui.messageBox('Select one row to delete.')
                else:
                    tableInput.deleteRow(tableInput.selectedRow)
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event handler that reacts when the command definitio is executed which
# results in the command being created and this event being fired.
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            # Get the command that was created.
            cmd = adsk.core.Command.cast(args.command)
            # Connect to the input changed event.
            onInputChanged = MyCommandInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            # Get the CommandInputs collection associated with the command.
            inputs = cmd.commandInputs
            # Create table input
            tableInput = inputs.addTableCommandInput('table', 'Table', 3, '1:1:1')
            # Add inputs into the table.
            addButtonInput = inputs.addBoolValueInput('tableAdd', 'Add', False, '', True)
            tableInput.addToolbarCommandInput(addButtonInput)
            deleteButtonInput = inputs.addBoolValueInput('tableDelete', 'Delete', False, '', True)
            tableInput.addToolbarCommandInput(deleteButtonInput)
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDefs :adsk.core.CommandDefinitions = _ui.commandDefinitions
        global _cmdInfo
        cmdDef :adsk.core.CommandDefinition = cmdDefs.itemById(_cmdInfo[0])
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = cmdDefs.addButtonDefinition(_cmdInfo[0],_cmdInfo[1],_cmdInfo[2])
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
JohnBuehler
Kandennti,
Thank you for the detailed explanation, it is extremely helpful!
John
