materials.itemByName() should return "null" but it doesn't
JeromeBriot
Mentor Mentor
JeromeBriot
import adsk
import traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        matLib = 'Fusion 360 Material Library'
        matName = 'ABS Plastic'
        # Get the library.
        lib = app.materialLibraries.itemByName(matLib)
        if not lib:
            ui.messageBox('"{}" not found'.format(matLib))
            return
        material = lib.materials.itemByName(matName)
        if not material:
            ui.messageBox('"{}" not found'.format(matName))
            return
        ui.messageBox('Succeed')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
When mispeling the material library name (matLib variable), the script above works as expected.
app.materialLibraries.itemByName() returns "null" and the first message box appears.
When mispeling the material name (matName variable), an exception occurs and the except clause is executed.
materials.itemByName() should return "null" but it doesn't. That's what the documentation says: Materials.itemByName Method.
A workaround:
import adsk
import traceback
def run(context):
    ui = None
    try:
        if not lib:
            return
        try:
        except:
            return
    except:
        if ui:
marshaltu
Thank you for reporting the issue to us. UP-36434 has been logged in our internal system to track it.
Marshal
Marshal Tu
Fusion Developer
