Issue with Displaying Palette Text on Application Start
p_krola
p_krola
I need help with an issue I'm facing. I want to display a palette with text that I send from a command when the application starts. I wrote a function to send a sample test:
This function works fine when I call it, for example, in:
However, when I try to call it right after creating the palette in the start() function, it doesn't execute palette_incoming. As a result, the data I wanted to send doesn't appear in the palette. Here is my palette_incoming function:
Start():
palette_incoming():
Here are the console logs:
Can someone suggest a way to trigger palette_incoming?
kandennti
Hi @p_krola -San.
Since we cannot test it, it may not be the correct answer.
I have created an add-in that displays the palette when the application is launched and published it here.
https://github.com/kantoku-code/Fusion360_Developers_Small_ToolKit/tree/main
I used the WorkspaceActivated event to call the palette.
https://github.com/kantoku-code/Fusion360_Developers_Small_ToolKit/blob/main/Developers_Small_ToolKi...
I have emptied the list holding the handler in the handler to prevent it from being called multiple times.
