Importing STL file as a mesh script error
benC5F9W
benC5F9W
I have a script that automatically imports an STL file as a mesh into fusion using the meshBodies.add() function. When I run this script I am getting a weird error that I have never seen before:
"RuntimeError: 2 : InternalValidationError : insertProcessor.execute(pInsertRequest.get())"
What is especially weird is that this script works perfectly fine if I use the selectFiles() function at the end of the script to prompt the user to select an STL file. This error only arises when I input the path to the file location of the STL file. This is the ideal way to use this as I don't want to have to select the file everytime.
If anyone can help me figure out what this error means and why it is only showing up when I put the file location in my script it would be much appreciated.
- Ben
Here is the code:
import adsk.core, adsk.fusion, adsk.cam, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        # import stl file
        path = r'Downloads\powder.stl'
        #Line below can be used to prompt user to select file instead of using file path
        #paths = selectFiles('select STL file')
        # new doc
        _app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        des  :adsk.fusion.Design = _app.activeProduct
        des.designType = adsk.fusion.DesignTypes.ParametricDesignType
        root :adsk.fusion.Component = des.rootComponent
        # baseFeature
        baseFeatures = root.features.baseFeatures
        baseFeature = baseFeatures.add()
        baseFeature.startEdit()
        # import obj files
        meshs = importMesh(path ,root.meshBodies, baseFeature)
        baseFeature.finishEdit()
        # finish
        _ui.messageBox('Done')
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def importMesh(
    path :list,
    meshBodies :adsk.fusion.MeshBodies,
    baseFeature :adsk.fusion.BaseFeature) -> list:
    unitCm = adsk.fusion.MeshUnits.CentimeterMeshUnit
    mesh = meshBodies.add(path, unitCm, baseFeature)
    return mesh
def selectFiles(
    msg :str):
    fileDlg = _ui.createFileDialog()
    fileDlg.isMultiSelectEnabled = True
    fileDlg.title = msg
    fileDlg.filter = '*.stl'
    dlgResult = fileDlg.showOpen()
    if dlgResult == adsk.core.DialogResults.DialogOK:
        return fileDlg.filenames
kandennti
Hi @benC5F9W -San.
How about using the MeshBodies.add method?
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-ebb740dc-6214-4097-affb-a9bfc7fd7e43
def run(context):
    try:
        global _app, _ui
        # import stl file
        # new doc
        # import stl
        meshs: adsk.fusion.MeshBodyList = root.meshBodies.add(
            path,
            adsk.fusion.MeshUnits.MillimeterMeshUnit,
        # finish
    except:
        if _ui:
benC5F9W
That actually is the method I am using, it is just inside my importMesh()  function (lines 45-54).
The MeshBodies.add() method is raising this error when trying to automatically import:
I am not sure what is causing this as all of my parameters for MeshBodies.add() seem correct.
kandennti
@benC5F9W -San.
I was mistaken.
Perhaps I specified the file path incorrectly.
If you are on windows, it probably looks like this.
path = r'C:\Users\<username>\Downloads\powder.stl'
