Issue with CHM API documentation file / july-2022 version
Jorge_Jaramillo
Jorge_Jaramillo
The CHM API documentation file I downloaded for the latest version (july-2022) seem to have some internal problem.  After I opened it and look for some reference inside, it freezes the right panel with a white page:
I tryied reopening and still get the same white page, even if I choose differentes references in the left panel.
I also downloaded it many times, and I got the same behavior.
Other version I have from may-2022 version works great, so I discarded any problem with the app itself.
I downloaded the file from the following page:
Hope you could resolve this issue since this is a valuable resource to make API-based developments.
Jorge
Rushikesh.kadam
@Jorge_Jaramillo I am able to use the chm without any problem. Are you observing the issue with all the references or any specific ones?
I using a Windows machine.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
BrianEkins
I'm guessing it's a permission problem. Here's a link that shows how to unblock it.
https://community.spiceworks.com/topic/1961503-solved-windows-10-chm-help-files-showing-up-blank
Brian Ekins
Jorge_Jaramillo
Hi @Rushikesh.kadam ,
The issue happen after 2 or 3 clicks on left panel, on any reference in the contents tab.
I have the same CHM version as you:
And this is the version of the utility (hh.exe):
I'm using a Windows 10 which is up-to-date.
The previous version of CHM file, which runs very well, has this timestamp:  "Help created: Monday, April 11, 2022 4:42 PM"
Thank you,
Jorge
Jorge_Jaramillo
Thank you @Anonymous,
It solve the problem.
Regards.
