Is the Design Automation API available (or going to be available) for Forge Fusion 360?
marcosscriven
marcosscriven
I'm seeing a few references to Forge now being available for Fusion 360 designs:
However, I can't see any reference yet on the official API docs: https://forge.autodesk.com/en/docs/design-automation/v3/developers_guide/overview/
What I'm looking to do is:
  1. Upload a Fusion 360 model to Forge
  2. Run an add-in (which if I understand correctly would be much the same as in Fusion 360 itself)
  3. Download the resultant model
kandennti
Hi @marcosscriven .
Probably there is no API provided to achieve that.
I'm not even sure if this is relevant, but I'll describe what I'm aware of.
A text command with a very interesting name was added in the August 2021 update (Ver. 2.0.10806).
If you actually try the command here, you will see a list of commands with a brief description.
AutomatedModeling /?
If you actually try it with Ver 2.0.11894, you will get this output.
AutomatedModeling - Commands related to Automated Modeling
    Host - Get/Set host, valid host name examples: http://localhost:3000(or "local"), http://ecs-6026ceaa.ecs.ads.autodesk.com (or "ecs"). Use "default" to restore default settings.
    Log - [/Off|/Normal|/Debug] Enable/disable logging of AM related activity
    Recipe - [/Path] Execute a recipe from JSON file
    SaveScalarisData - Write a scalaris folder to disk.
    SetServerCheckIntervals - [/interval_name interval_value] Set intervals values for AMJobController. You can provide more than one in single command.
    SolverConfig - Loads solver custom metadata from JSON config file
    ToggleFeature - It toggles ON/OFF given Feature Types for Generative Modelling. If used with no parameters displays available options. [/Features...]
    ToggleSolver - It toggles ON/OFF given solvers for Generative Modelling. If used with no parameters displays available solvers. [/Solvers...]
    WaitForSolvers - Wait until either unfinished solvers are done or timeout is reached
I don't know how to use this command at all, so I haven't even tried it.
There is an add-in called f360dever published by @prainsberry .
In it, there is a file called "ForgeCommands.py" which I think is a function to access Forge.
https://github.com/tapnair/f360dever/blob/master/commands/ForgeCommands.py
I haven't tried anything with it either.
marcosscriven
Thanks for the response, however I was looking for a definite answer from Autodesk themselves. Also, this API certainly does exist in Forge right? It's just a question of if/whether Fusion 360 is going to be fully integrated with Forge.
kandennti
@marcosscriven .
Expert Elite members is not an Autodesk employee, but a user just like you.
This is not an official answer, but my personal opinion.
BrianEkins
I'll also add my personal opinion.  You won't tend to get a response for long-term futures from Autodesk because plans can change and they don't want to set expectations for something that might not happen.  My opinion is that I wouldn't plan any near-term development activity around this capability.
Brian Ekins
