- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Somehow lost my narrative of the problem here so will add it again. I installed the Airfoil DAT to Spline script from the autodesk app store. Install seemed OK. Script works OK up until the dat file is referenced and then gives this error. Have tried varying inputs but still no luck. Have seen this script used successfully on videos posted to youtube. Any tips would be welcome.
Peter
Contact the author of this add-in: @Anonymous
Attach the dat file could also be useful.
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Hi!
Could you say what construction plane do you use?
It should be parallel to one of origin. XY, XZ or YZ. Angled planes doesn't work.
Please send me all details by e-mail as I don't monitor activity on forum. I want to reproduce your error. The DAT file will help as well.
Thanks!
Thanks very much - that was indeed my problem.
Thank you
