Install Image2surface-master script
Message 1 of 10
I've never been able to get this script Image2surface to work and thought I'd have another crack? I note that it's recently been updated and converted from javascript to Python. I've downloaded it from Github but when I get into opening the file directory to suss out why Fusion can't open it, I can see the files 4.39MB, when I hover the mouse over the folder, but when I double click the folder, it's empty.
I can see the effects of the script whilst in Github, as in generate a surface map, so I believe it'll be a worthwhile addition to the Fusion 360 armoury, BUT, the devil's in the detail?
Replies (9)
Message 2 of 10
daniel_lyall
Remove -Master scripts from the name
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 10
I don't think that's the issue? Tried another approach and got the downloaded folder into C:Users>paul>AppData>Roaming>Autodesk>Autodesk Fusion 360>API>Scripts>Fusion360Image2Surface-master
F360 'Scripts and Add-ins' refer to 'My Scripts' > Fusion360Image2Surface-master I click on that and 'Run' and get a new box 'Hello script' with an 'OK' button. Hit 'OK' , the box disappears and nothing happens!
Message 4 of 10
daniel_lyall
remove -master and just try it
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 10
Sorry Lyall, I did previously. I get the 'Error' message  "A single script or add-in cannot be identified in the selected folder. Please organise your programs so each script or add-in is in its own folder"...?
Message 6 of 10
daniel_lyall
I had the same problem removing -master was the only fix
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 10
Thanks Daniel for your effort, but I'm still left scratching my head? Might try and contact Hans Kellner, the original author of the script?
Message 8 of 10
JeromeBriot
Fusion360Image2Surface is now an add-in (see the "type" entry in the manifest file). So you have to copy files under this directory:
C:Users>paul>AppData>Roaming>Autodesk>Autodesk Fusion 360>API>Addins>
Did you try GitHub2Fusion360? It's the easiest way to install scripts or add-ins from GitHub.
Message 9 of 10
Jerome! well you've provided the answer in a way? Being an app and not a script got it going. Thankyou, however I was intrigued by your app, but couldn't launch it after downloading? Tried 3 times but it never appeared in Fusion Add ins? Had enough for one day, so might try again tomorrow.
Message 10 of 10
Apologies Jerome, as I was shutting the computer down, I discovered that virus protection hed prevented the launch! So, all good now. Thanks again.
