How to reference a feature by its name?
luca.giorcelli
Message 1 of 8
luca.giorcelli
I'm sure it's incredibly simple, but I've been searching for hours and haven't figured it out yet.
I just want to suppress a feature named "myFeature" in timeline using the Feature.isSuppressed Property
In API reference I find the following
feature_var.isSuppressed = True
Where "feature_var" is a variable referencing a Feature object.
QUESTION
What the right way to reference a Feature by its name? I suppose something like this...
getFeatureByName("myFeature").isSuppressed = True
Please can you tell me the right syntax?
Replies (7)
Message 2 of 8
JeromeBriot
Try something like this :
features= rootComp.features
myFeature = features.itemByName('myFeature')
myFeature.deleteMe()
Message 3 of 8
luca.giorcelli
@JeromeBriot thanks, it works!
Message 4 of 8
JeromeBriot
Sorry, I should have posted a complete code:
import adsk.core, adsk.fusion, traceback
def run():
    app = adsk.core.Application.get()
    ui = app.userInterface
    try:
        design = app.activeProduct
        rootComponent = design.rootComponent
        features= rootComponent.features
        if myFeature:
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Message 5 of 8
luca.giorcelli
itemByName seems to works only if the feature belongs to root component. But I'm not able to reference a feature inside a child component.
In the example below I unsuccessfully try to suppress featureB inside childComponent:1
The code used is the following
def run(context):
    ui = None
    try:
        app :adsk.core.Application = adsk.core.Application.get()
        ui  :adsk.core.UserInterface = app.userInterface
        design :adsk.fusion.Design = app.activeProduct
        rootComp = design.rootComponent
        features = rootComp.features
        features.itemByName("featureB").isSuppressed = True
    except:
        if ui:
The error I get is the following one
Instead, everything works well if I try tu suppress featureA (belonging to root component) using the same code above.
Is there some syntax to reference features inside subcomponents? E.g. something like "childComponent1:/featureB".
Message 6 of 8
JeromeBriot
You can iterate through all the components in the current design:
def run(context):
    try:
        design = adsk.fusion.Design.cast(app.activeProduct)
        allComponents = design.allComponents
        for component in allComponents:
            features = component.features
            feature = features.itemByName('featureA')
            if feature:
                ui.messageBox('{} - {}'.format(component.name, feature.name))
                feature.deleteMe()
            feature = features.itemByName('featureB')
            if feature:
                feature.deleteMe()
    except:
        if ui:
Message 7 of 8
luca.giorcelli
Thanks! It works
Message 8 of 8
luca.giorcelli9CG7C
I've run the script with a more complex design. The differences are as follows:
  • nested components (on multiple levels)
  • shared designs
  • sheet metal bended components.
While iterating trough components, I get this error:
I cannot understand the meaning. Some advice? Thanks.
