How to get the trimming information of a point in face
2544173825
Message 1 of 9
2544173825
As the question, I want to get the trimming information of a point, but I can't find the relevant method, does Fusion360API provide the relevant method?
Replies (8)
Message 2 of 9
kandennti
Hi @2544173825 .
I did not understand what you meant by trimming information on points.
If you could be a little more specific by adding images and 3D data, we might be able to help, including others.
Message 3 of 9
2544173825
What I said about getting trimming information is the function implemented by this function, which I saw inside another library, and I don't know if Fusion 360 has a similar function.
Message 4 of 9
BrianEkins
Based on the comment "Check if the uv-coordinate is on the visible region of the face", I think you probably want to use the SurfaceEvaluator.isParameterOnFace method. The documentation for this method needs to be corrected. It says it checks to see if the point lies within the parametric range. This is true but it also takes into account any boundaries on the face.
Brian Ekins
Message 5 of 9
2544173825
Thanks!
Message 6 of 9
2544173825
@BrianEkins @kandennti
But I don't think that's the answer I'm looking for, and my goal is to get the trimming information of this point by passing a parameter to the function that encloses the point of the parameter in the box. I uploaded a ZIP file which will show the result and 3D data of a trimming information (json file) that I want to extract, this json file also includes some other information, just ignore it, thanks a lot!
Message 7 of 9
kandennti
Message 8 of 9
2544173825
Well, thank you anyway!
Message 9 of 9
2544173825
