Hi @2544173825 .
The parameter of the getPointAtParameter method is a Point2D object.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-761b2324-dc33-42b5-b6a9-b3a1305b8341
Also, I believe that you can get the normal vector from a point on the surface, but you should not be able to define the tangent information.
If you have another vector, you should be able to get the tangent by using the outer product.
Here is a sample of drawing normals on a 10x10 selected surface.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
SPLIT_COUNT = 10
def run(context):
ui = adsk.core.UserInterface.cast(None)
try:
app: adsk.core.Application = adsk.core.Application.get()
ui = app.userInterface
des: adsk.fusion.Design = app.activeProduct
root: adsk.fusion.Component = des.rootComponent
# select face
msg: str = 'Select Face'
selFilter: str = 'Faces'
sel: adsk.core.Selection = selectEnt(msg, selFilter)
if not sel:
return
selectFace: adsk.fusion.BRepFace = sel.entity
# create parameter
eva: adsk.core.SurfaceEvaluator = selectFace.evaluator
bBox: adsk.core.BoundingBox2D = eva.parametricRange()
ratio = 1 / SPLIT_COUNT
pichX = (bBox.maxPoint.x - bBox.minPoint.x) * ratio
pichY = (bBox.maxPoint.y - bBox.minPoint.y) * ratio
prms = []
for idxX in range(SPLIT_COUNT + 1):
for idxY in range(SPLIT_COUNT + 1):
prms.append(
adsk.core.Point2D.create(
pichX * idxX,
pichY * idxY
# get points
_, points = eva.getPointsAtParameters(prms)
# get normals
_, normals = eva.getNormalsAtParameters(prms)
# create sketch
skt: adsk.fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
# draw normals
sktLines: adsk.fusion.SketchLines = skt.sketchCurves.sketchLines
targetPoints = [p.copy() for p in points]
[p.translateBy(v) for p, v in zip(targetPoints, normals)]
skt.isComputeDeferred = True
[sktLines.addByTwoPoints(p1, p2) for p1, p2 in zip(points, targetPoints)]
skt.isComputeDeferred = False
ui.messageBox('done')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def selectEnt(
msg: str,
filterStr: str) -> adsk.core.Selection:
try:
ui: adsk.core.UserInterface = app.userInterface
sel = ui.selectEntity(msg, filterStr)
return sel
except:
return None
You seem to have created something that looks like fun. Looking forward to it.
