How to find the latest the ThreadData folder on all platforms?
thomasa88
thomasa88
I have created the add-in ThreadKeeper, which copies threads into Fusion's ThreadData folder every time Fusion is updated.
I have previously based the look-up on app.userInterface.workspaces.itemById('FusionSolidEnvironment').resourceFolder to find webdeploy/production/<hash>/...../ThreadData, but I have now hit a use-case where this method fails. The problem happens on a Mac.
The resourceFolder is
/Applications/Autodesk Fusion.app/Contents/Libraries/Applications/Fusion/Fusion/UI/FusionUI/Resources/Environment/Model ,
while the user's ThreadData folder is
/Users/<user>/Library/Application Support/Autodesk/webdeploy/production/<letters and numbers>/Autodesk Fusion.app/Contents/Libraries/Applications/Fusion/Fusion/Server/Fusion/Configuration/
What is the best way to look up the ThreadData folder?
I asked the user for the paths in Application.applicationFolders and the text command "paths.get", but none contains when webdeploy path.
thomasa88
I may have figured out two hacky ways that seem to work on Windows. I will ask the user to test them on Mac.
sys.argv[0]
C:\\Users\\Thomas\\AppData\\Local\\Autodesk\\webdeploy\\production\\ca305acf3852cfce8e837ee5435adf649bc398ca\\Fusion360.exe
sys.executable
C:/Users/Thomas/AppData/Local/Autodesk/webdeploy/production/ca305acf3852cfce8e837ee5435adf649bc398ca/Python\\python
Jorge_Jaramillo
This code snipped based on the 'paths.get' text command works for me in windows:
import json
import adsk
import adsk.core
import adsk.fusion
app = adsk.core.Application.get()
def run(context) -> None:
    try:
        paths: dict[str, str] = json.loads(app.executeTextCommand('paths.get'))
        app.log(f'rootDirectory: {paths["rootDirectory"]}')
    except Exception:
        app.log('Failed:\n{}'.format(traceback.format_exc()))
    adsk.terminate()
It produces the following output:
rootDirectory: C:/Users/<username>/AppData/Local/Autodesk/webdeploy/production/ca305acf3852cfce8e837ee5435adf649bc398ca/
Then you can append "Fusion/Server/Fusion/Configuration/ThreadData" to get the full directory path.
I don't have a Mac environment to test it over there, but I'd expect the result is the same.
Jorge Jaramillo
thomasa88
Unfortunately, on Mac, it seems to be possible to install Fusion in a way that puts files in /Applications, without "webdeploy" and version in the path, while the ThreadData still resides under webdeploy/production/version.
The user reported that e.g. paths.get -> rootDirectory gave "rootDirectory: /Applications/Autodesk Fusion.app/Contents/Libraries/Neutron/" (linked as "paths.get" in my original post), while ThreadData is in /Users/<user>/Library/Application Support/Autodesk/webdeploy/production/<letters and numbers>/Autodesk Fusion.app/Contents/Libraries/Applications/Fusion/Fusion/Server/Fusion/Configuration/ThreadData.
My workaround using sys.argv[0] or sys.executable failed, as they did not provide the webdeploy path either 😕 .
