How to Exit / Stop Fusion API Script From Within Script (Throw Fatal Error)
therealsamchaney
therealsamchaney
Hi, is it possible to throw an exception that will end/stop a Fusion 360 API script? Basically, I want to check something (for instance a folder directory given by a user) and if they give a bad path, exit the entire Fusion script (or stop the Run function) from within a function block. I've tried sys.exit() but it's not working as expected. I know the ui.inputBox has a cancel method that can exit the script so it would be great to be able to do something like that.
Thanks!
therealsamchaney
I did get sys.exit() to work but it has to not be in a try/except block. I'm still wondering if there is a more Fusion API way to do this, like if there is a built-in cancel or exit method to stop scripts so I would say this doesn't really answer my original question.
If anyone is wondering, my code is below. It's a simple function to get a file folder path from the user.
        def get_path():
            export_path, cancelled = ui.inputBox('Enter path to the export folder')
            if cancelled:
                ui.messageBox('Cancelled')
                sys.exit('Cancelled')
            if not os.path.isdir(export_path):
                ui.messageBox('Path does not exist. Aborting program')
                sys.exit('Path does not exist')
            export_path = os.path.abspath(export_path)
            export_path+='\\'
            return export_path
One thing I noticed is that if you have a ui.inputBox call inside a function block, the cancel method doesn't actually end the script (hence why I had to have the second sys.exit). However, if you call the ui.inputBox method outside a block (just in the main run function), it does actually end the script. Must be a quirk about how cancel works. I looked into fusion.py and found the cancel method but it just calls TrimFeatureInput_cancel(self) and I can't find the definition for that method.
kandennti
Hi @therealsamchaney .
Instead of aborting in the get_path function, how about aborting in the caller?
Also, since the UserInterface object has createFileDialog and createFolderDialog, I think it would be more user-friendly to use them.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
import os
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        export_path: str = get_folder_path()
        if len(export_path) < 1:
            return
        ui.messageBox(export_path)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def get_folder_path() -> str:
    ui: adsk.core.UserInterface = app.userInterface
    dlg: adsk.core.FolderDialog = ui.createFolderDialog()
    res: adsk.core.DialogResults = dlg.showDialog()
    if res:
        return ''
    export_path: str = dlg.folder
        return ''
    return export_path + '\\'
therealsamchaney
Thank you. I had thought about aborting in the caller, that might be better. I did not know about createFileDialog or createFolderDialog, so thank you. That is definitely better than the inputBox I was using. I am new to the API so there is a lot I don't know about yet. This should definitely improve my script!
あなたのバイオは日本語があります。日本語は話せますか?勉強しています
kandennti
@therealsamchaney .
I don't understand anything but Japanese.
私の英語より、きれいな日本語になっていますよ。
