Stop Addin From Running
isocam
isocam
Can anybody help?
I have a Fusion 360 Python addin that "Runs on Startup"
The user, can set an external parameter to switch on or off the application (via the registry), even though the addin is still running in the background.
At present, if the user has switched off the application, I have put a "return" in my code.
Is it possible to  completely stop/end the application via Python so that the api is no longer running in the background?
Many thanks
Darren
tykapl.breuil
I think the adsk.terminate() function does exactly what you wish for !
