how find point on face
Message 1 of 9
how find point(A) on select face (TRUE/FALSE)
Replies (8)
Message 2 of 9
marshaltu
Please refer to the following sample for how to judge if a point is on face or not.
Marshal
import adsk.core, adsk.fusion, traceback
def run(context):
  ui = None
  try:
    app = adsk.core.Application.get()
    ui  = app.userInterface
    face = adsk.fusion.BRepFace.cast(ui.activeSelections.item(0).entity)
    pointA = adsk.core.Point3D.create(0, -0, 2)
    res, paramA = face.evaluator.getParameterAtPoint(pointA)
    res, newPoint = face.evaluator.getPointAtParameter(paramA)
    if pointA.isEqualToByTolerance(newPoint, 0.01):
        ui.messageBox('Point A is on the face.')
    else:
        ui.messageBox('Point A is not on the face.')
  except:
    if ui:
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion Developer
Message 3 of 9
amargett
Observer
Observer
I am trying to find a way to take a body and find a set of x,y,z coordinates on that body. I tried this method, but Fusion runs forever once I run the script and I have to restart Fusion every time I try to edit the code.
Is there a better way to find x,y,z point coordinates on a body?
Also, how would I get the script to quit itself once I know it will be running forever?
Ashley
Message 4 of 9
BrianEkins
What are your requirements for the point on the face, since there are an infinite number of points on a face? If you only care that the point is on the face, I would recommend using the BRepFace.pointOnFace property.
Brian Ekins
Message 5 of 9
amargett
Observer
Observer
This is helpful to generate one point on a face, but is there a way to use this function to generate, say, 200 different points on the same face?
Message 6 of 9
kandennti
Hi @amargett .
We have created a sample that uses SurfaceEvaluator to randomly create 200 sketch points.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
import random
POINT_COUNT = 200
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        msg: str = 'Select Face'
        selFilter: str = 'Faces'
        sel: adsk.core.Selection = selectEnt(msg, selFilter)
        if not sel:
            return
        createPointsOnFace(
            sel.entity,
            POINT_COUNT
        ui.messageBox('Done')
    except:
        if ui:
def createPointsOnFace(
    face: adsk.fusion.BRepFace,
    count: int) -> adsk.fusion.Sketch:
    # Evaluator
    eva: adsk.core.SurfaceEvaluator = face.evaluator
    # Parameter Range
    prmRange: adsk.core.BoundingBox2D = eva.parametricRange()
    prmMin: adsk.core.Point2D = prmRange.minPoint
    prmMax: adsk.core.Point2D = prmRange.maxPoint
    # Parameters On Face
    prmsOnFace = []
    while len(prmsOnFace) < count + 1:
        prmLst = [
            (random.uniform(prmMin.x, prmMax.x), random.uniform(prmMin.y, prmMax.y))
            for _ in range(count)
        prmLst = list(set(prmLst) - set(prmsOnFace))
        for x, y in prmLst:
            prm: adsk.core.Point2D = adsk.core.Point2D.create(x, y)
            if eva.isParameterOnFace(prm):
                prmsOnFace.append((x, y))
    # Points on Face
    prms = [adsk.core.Point2D.create(x, y) for x, y in prmsOnFace]
    _, pnts = eva.getPointsAtParameters(prms)
    # Draw Points
    comp: adsk.fusion.Component = face.body.parentComponent
    skt: adsk.fusion.Sketch = comp.sketches.add(comp.xYConstructionPlane)
    skt.isComputeDeferred = True
    for pnt in pnts:
        skt.sketchPoints.add(pnt)
    skt.isComputeDeferred = False
    return skt
def selectEnt(
        msg: str,
        filterStr: str) -> adsk.core.Selection:
    try:
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
Message 7 of 9
amargett
Observer
Observer
This was really helpful. Thank you so much!
I was able to generate the points, but I want to save the position of these shapes for use in a different software. I am able to display them through a UI message box, but the box isn't big enough to return all the points. Is there a way to open and write txt files through the API? I tried but got the error: '[Errno 30] Read-only file system: 'pointvals.txt' fusion 360'
Thanks again!
Message 8 of 9
BrianEkins
The API doesn't support writing to files but Python does. Just do a quick Google search of writing to a file with Python and you should see a lot of results.
Brian Ekins
Message 9 of 9
kandennti
@amargett .
import traceback
import adsk.fusion
import adsk.core
import random
import csv
EXPORT_PATH = r'C:\temp\points.csv'
    # Points on Face
    # write file  Unit Cm
    pointsLst = [p.asArray() for p in pnts]
    with open(EXPORT_PATH, 'w') as f:
        writer = csv.writer(f)
        writer.writerows(pointsLst)
