Cone isExpanding
Cone isExpanding
rolandas_vegis
Message 1 of 9
Cone isExpanding
rolandas_vegis
How to find out whether a cone is expanding or not? Cone object doesn’t have that property and there doesn’t seem to be a way to calculate it from existing properties. Inventor Cone object has isExpanding property.
Replies (8)
Message 2 of 9
marshaltu
There is no expanding property in geometry object "Cone". It would be good if you can explain a little bit about the workflow what you are going to do. We can probably find a workaround for you.
Marshal
Marshal Tu
Fusion Developer
Message 3 of 9
rolandas_vegis
Was writing a method to calculate whether a cylinder is interior or exterior. How should I calculate it for cones without the is expanding property?
Message 4 of 9
marshaltu
I assume there is a context for cylinder or cone. Otherwise it seems that there is no way to calculate that. For the example the snapshot shows. There are two cone surfaces: interior and exterior. We can differentiate it by the normal on parameter point (0.5, 0.5).
Marshal
import adsk.core, adsk.fusion, traceback
def run(context):
  ui = None
  try:
    app = adsk.core.Application.get()
    ui  = app.userInterface
    face = adsk.fusion.BRepFace.cast(ui.activeSelections.item(0).entity)
    res, normal = face.evaluator.getNormalAtParameter(adsk.core.Point2D.create(0.5, 0.5))
    ui.messageBox('Axis is {}, {}, {}'.format(normal.x, normal.y, normal.z))
  except:
    if ui:
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion Developer
Message 5 of 9
marshaltu
I realized the previous solution would not work if there is only one cone surface. The following codes just show how to judge if cone is interior or exterior by the angle between the normal and axis of cone surface. If it is larger than 90 degree, the cone is interior. Otherwise it is exterior.
Marshal
import math
def run(context):
  ui = None
  try:
    cone = adsk.core.Cone.cast(face.geometry)
    angle = normal.angleTo(cone.axis) * 180.0 / math.pi
    ui.messageBox('Axis is {}'.format(angle))
  except:
    if ui:
Marshal Tu
Fusion Developer
Message 6 of 9
VismantasKizelis
Hello
It happens that cone axis returned by API does not always match the cone direction. I got a model of two cones pointing differend directions, but API returns Vector3D(0, 0, -1) for both of them. So one cone has angle between axis and normal >90 and other cone has angle <90 degrees, but both are exterior cones.
Message 7 of 9
marshaltu
It would be good if you share a copy of the design to me. I can take a look then.
Marshal
Marshal Tu
Fusion Developer
Message 8 of 9
VismantasKizelis
Message 9 of 9
marshaltu
I changed the codes a little bit. It should work well for your case now. Please give a try.
Marshal
import math
def run(context):
  ui = None
  try:
    origin = cone.origin
    res2, point = face.evaluator.getPointAtParameter(adsk.core.Point2D.create(0.5, 0.5))
    axis = adsk.core.Vector3D.create(point.x - origin.x, point.y - origin.y, point.z - origin.z)
    angle = normal.angleTo(axis) * 180.0 / math.pi
    ui.messageBox('Angle is {}'.format(angle))
  except:
    if ui:
Marshal Tu
Fusion Developer
