How does one use a Batch file to Open Fusion 360, Run few dll files in sequence?
tperam
tperam
How does one use a Batch file to Open Fusion 360, Run few dll files in sequence one after the other created in Visual Studio C++, Then Close Fusion 360.
Can I pass parameters from the batch file into Visual Studio C++?
Thurai.
PinRudolf
Hi, I'm not sure if this fits your needs:
Use a batch file to start fusion and create a setup-sheet. On the start of fusion you could get some add-ins to run that would read out the setup-sheet and can than call the appropriate dll's?
Using the setup sheet you should be able to pass parameters ass well.
tperam
Hi  PinRudolf,
                       Thanks for your response.
I will try your steps and see how it goes.
Thurai
