How do I select point on a body like you can when you create a joint?
adonno
adonno
I would like to have a selection object in my script's input dialog that would allow me to select a point on an existing body in a similar way to how the regular UI allows you to do that when creating a joint. Example
marshaltu
Unfortunately it is not normal selection behaviour in Joint command and so there was no API for expose it. You may have to customize selection by yourself if you want same behaviour. The selection event should be one you can start with.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3044adfb-f8b9-46ba-bb26-1b6316757537
Marshal
Marshal Tu
Fusion Developer
adonno
OK, thanks. I had sort-of come to that conclusion myself. Thanks for confirming.
