I want to install some third party packages into the Fusion python interpreter in a robust way. I understand one solution is to just include the dependency source code directly within my add-in. I don't want to do this. Instead, I'm trying to run pip from within the python interpreter to install directly to the Fusion python. I tried the following script:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
ui = None
try:
text = "Lorem ipsum dolor sit amet"
def install_and_import(package):
import importlib
try:
importlib.import_module(package)
except ImportError:
import pip
pip.main(['install', package])
finally:
globals()[package] = importlib.import_module(package)
app = adsk.core.Application.get()
ui = app.userInterface
install_and_import('transliterate')
msg = transliterate.translit(text, 'hy')
ui.messageBox(msg)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))It should install transliterate package, but instead, when running the command pip.main(['install', package]) all I get is the following message:
Collecting transliterate Downloading transliterate-1.10-py2.py3-none-any.whl (49kB) 2
The console in Spyder never shows a message that the package was actually installed... it was just downloaded. I checked the same command on my own python interpreter (3.6), and it worked fine, giving a downloading, collecting and installing message. My question is: what did I do wrong? and how do I get pip to successfully install a package?
