Handling fractional dimensions within a script.
macmanpb
macmanpb
What is the best way to get a decimal from a fractional dimension.
In the design the dim is entered like >>3"/15<<. Is FusionUnitsManager the key or have i do something more to convert them back and forth?
MichaelT_123
Hi Mr. MacManPB,
Internally dimensions of length are represented as a value of centimeters and handled via a structure called  Parameter Object
Thus,
- parameter. value stores ... well length value
parameter. unit stores ... well, instruction haw the value is presented via an interface.
   Changing it will result in the appropriate display outcome.
- parameter.expression is ... the third leg complementing the schema.
Regards
MichaelT
MichaelT
