I can`t export a model to a single file if it contains an another linked model.
I am writing a Python plugin for printing that prints highlighted parts. To do this, I need to export them in the format "STL" in one file. Export occurs normally if the project has no linked models, or linked model is in the project root. But if there is an linked model in the project, in which there is also an linked model (the second level of nesting of linked models), then the API output the errors.
For export, when the associated model is at the root, I had to create a temporary occurrence at the project  root and copy the selected components in this occurrence. And break the connection of the copied models. This is done because the export function does not work differently!  After export, I delete this occurrence. But this method does not work when there is another related in the associated model. As shown in the figures:
Example of error:
"File" ....../MakerBotPlugin.py ", line 170, in exportToDisk
    occurence.deleteMe ()
  File "C: / ...... /AppData / Local / Autodesk / webdeploy / production / ...... / Api / Python / packages \ adsk \ fusion.py", line 18955, in deleteMe
    return _fusion.Occurrence_deleteMe (self)
RuntimeError: 5: MoveFace1 / Compute Failed // //).
    Try adjusting the values ​​or changing the input geometry."
Part of the export code in the attachment. Does anyone know  - is there any way to export models, regardless of their linked state and nesting level?
I can`t add the attachment file. So add the part of the export code there:
# TODO: Fix the code in the future after appearance of a normal API for copying or export bodies.
def exportToDisk(selection, isSelectedAll):
    tempDir = None
    try:
        app = adsk.core.Application.get()
        design = adsk.fusion.Design.cast(app.activeProduct)
        exportMgr = design.exportManager
        rootComp = design.rootComponent
        tempDir = tempfile.TemporaryDirectory()
        occurenceCopies = []
        if isSelectedAll:
            # NOTE: Add all bodies, but linked bodies will not be exported.
            selectedBodies = [body for body in rootComp.bRepBodies]
            # NOTE: Create unlinked copies of occurences, and add to the 'bodies' list.
            for occ in rootComp.allOccurrences:
                if (occ.isReferencedComponent):
                    occurenceCopy = U.addUnlinkedCopyToRoot(rootComp, occ)
                    occurenceCopies.append(occurenceCopy)
                    occ = occurenceCopy
                for body in occ.component.bRepBodies:
                    selectedBodies.append(body)
        else:
            selectedBodies = [selection.selection(index).entity for index in range(selection.selectionCount)]
                    # NOTE: Append the copy of the linked body.
                        if any(body.revisionId == selectedBody.revisionId for selectedBody in selectedBodies):
                            selectedBodies.append(occurenceCopy.component.bRepBodies.itemByName(body.name))
        solidCopyComponent = createSolidCopy(selectedBodies)
        fileName = os.path.join(tempDir.name, U.getRootName(rootComp))
        stlExportOptions = exportMgr.createSTLExportOptions(solidCopyComponent, fileName)
        stlExportOptions.sendToPrintUtility = False
        exportMgr.execute(stlExportOptions)
        # NOTE: Remove temporary objects.
        for occurence in list(rootComp.occurrences):
            if occurence.isValid and occurence.component.name == solidCopyComponent.name:
                occurence.deleteMe()
        for occurence in list(occurenceCopies):
    except Exception:
        U.showErrorMessage('An unresolved error occured!' + traceback.format_exc())
    return tempDir
def createSolidCopy(bodies):
    rootComp = adsk.fusion.Design.cast(adsk.core.Application.get().activeProduct).rootComponent
    solidCopyComponent = rootComp.occurrences.addNewComponent(adsk.core.Matrix3D.create()).component
    solidCopyComponent.name = uid('SolidCopyComponent')
    sourceBodies = adsk.core.ObjectCollection.create()
    for body in bodies:
        sourceBodies.add(body)
    design = adsk.fusion.Design.cast(adsk.core.Application.get().activeProduct)
    # NOTE: We need to do this because the CopyPasteBody feature is not supported in Direct Design.
    isDirectMode = design.designType == adsk.fusion.DesignTypes.DirectDesignType
    if isDirectMode:
        design.designType = adsk.fusion.DesignTypes.ParametricDesignType
    solidCopyComponent.features.copyPasteBodies.add(sourceBodies)
    if isDirectMode:
        design.designType = adsk.fusion.DesignTypes.DirectDesignType
    return solidCopyComponent
