Grounding component/occurrence
brad.bylls
brad.bylls
How do you ground a component with the API?
I tried:
component.isGrounded = True
componentOcc.isGrounded = True
Doesn't work.
Any help appreciated.
Brad Bylls
Accepted solutions (3)
davemwhiteley
Hi Brad,
I know it's been a while, but I came across your post with the same problem.,
You need to get the occurrence and ground that, i.e.
            product = app.activeProduct
            design = adsk.fusion.Design.cast(product)
            rootComp = design.rootComponent
            occ0 = rootComp.occurrences.itemByName('Box:3')
            occ0.isGrounded=True
I hope this helps?
brad.bylls
Thank you Dave.
Brad Bylls
MichaelT_123
Hi Mr Brad.Bylls
Consider looking into the few years old conversation:
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/i-am-isgrounded/m-p/7169797
I am not sure if the API ground is still the same, but ...
Regards
MichaelT
MichaelT
brad.bylls
@MichaelT_123
This what I ended up using at the time.
	root = design.rootComponent
	occ = root.occurrences.item(0)
	comp = occ.component
	subOcc1 = comp.occurrences.item(0)
	subOcc1Proxy = subOcc1.createForAssemblyContext(occ)
	subOcc1Proxy.isGrounded = True
Thanks for the input.
Brad
Brad Bylls
