getting center of mass in mm
fusion360_Admin4QV4K
Hello.
I am trying to write a script to parse through all components and write their XYZ coordinates to a file. So far everything works except the XYZ coordinates. What I get are insanely large values. How can I convert these values to say.. MM?
Example:
if I use "x = child.physicalProperties.centerOfMass.x"
I will get a HUGE number like -0.2487257213245866
(the actual value in mm is 26.5002)
I am trying to get the center of mass.
BrianEkins
You might want to look at the User Manual topic on units. When using the API, all distance values are in centimeters. The value you're seeing is in centimeters. The value (-0.2487257213245866) is not big. There's a decimal point at the beginning so it's less than 1/4 of the centimeter or -2.487 mm. There are a lot of digits because Fusion is doing the calculations using double-precision floating point numbers. Using formatting options, you can always choose to round to a specific precision. You can also use the UnitsManager object to convert the value into a string that uses the user's current units and the precision they've specified in their preferences.
Brian Ekins
kandennti
Hi @fusion360_Admin4QV4K .
Fusion360's internal unit of length is "Cm".
It is recommended to use the UnitsManager.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-GUID-9c2d17c1-70c6-4c2d-ae9e-c6f6f283b1a9
If you have set the unit of length to "mm", it will look like this.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        unitsMgr: core.UnitsManager = des.unitsManager
        occ: fusion.Occurrence = None
        for occ in root.allOccurrences:
            props: fusion.PhysicalProperties = occ.physicalProperties
            cog: core.Point3D = props.centerOfMass
            infos = [
                f'** {occ.name} - Center Of Mass**',
                f'X:{unitsMgr.formatInternalValue(cog.x)}',
                f'Y:{unitsMgr.formatInternalValue(cog.y)}',
                f'Z:{unitsMgr.formatInternalValue(cog.z)}',
            app.log('\n'.join(infos))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
If you want to specify the unit, you can change it to this.
                f'X:{unitsMgr.formatInternalValue(cog.x, "mm")}',
                f'Y:{unitsMgr.formatInternalValue(cog.y, "mm")}',
                f'Z:{unitsMgr.formatInternalValue(cog.z, "mm")}',
