Get Polyline3D from points
Joshua.mursic
Joshua.mursic
I have an interesting problem that I am struggling to find a solution for. I have an unordered list of points in a sketch, and I am trying to create the 3 paths as Polyline3D objects in fusion. I get these point clouds from a different software and need a method to detect paths based on proximity. maybe someone has one something similar here before.
MichaelT_123
Hi Mr Joshua.Mursic,
... sort the points by an ordered distance. Applying the direction vector to each scalar distance value might also help.
Sort the list, apply some tricks if you know something else about the points set, e.g if one of coordinates define "slice", do pre-subseting.
Regards
MichaelT
MichaelT
Joshua.mursic
Thanks for the help! I was able to get something to work for me.
