InternalValidationError : ASMInterface::getFaceCenterPoint(pFace, centPt)
gnm4pm
gnm4pm
I'm getting a new error since the most recent update when I try to find the centroid of a face. It doesn't affect every centroid call I make, and there doesn't seem to be any sort of pattern I can find. This previously was not a problem and I know the code was working before as I had used in many times on the exact same file under the exact same conditions.
Error:
I'm curious if anyone has seen an error like this before and if they have any solutions/workarounds.
BrianEkins
Can you please post a design that can be used to reproduce this problem?
Brian Ekins
gnm4pm
I spent some time yesterday readjusting my sort function to filter by a boundingbox range,  which I think improves my previous method anyway, so I am no longer experiencing the problem.  I think there is a specific problem with the way I generate one of my faces that throws the error as I can still find the centroid of other faces on the body. Either way, here is a simplified version of the code and f3z file that comes up with an error.
import adsk.core, adsk.fusion
app = adsk.core.Application.get()
design = app.activeProduct
root = design.rootComponent
for faces in root.bRepBodies.itemByName("Body1").faces:
    if faces.centroid.y > -10:
        print('success')
BrianEkins
One of the faces has a problem. It's the small face identified below. I deleted it and tried to recreate it using a Patch feature, but it was just as bad, if not worse. It would be good to report the Patch problem on the Fusion Support forum.
I used a convoluted method to create a better surface where the centroid can be calculated. The new model is attached.
Brian Ekins
