Get Point values from ObjectCollection of Point3D
rocco.mayr
rocco.mayr
In my script I added some points to a ObjectCollection
segmentPoints = adsk.core.ObjectCollection.create()
segmentPoints.add(adsk.core.Point3D.create(centerX, centerY, centerY))
How do I get the x, y, z values later on?
posX = segmentPoints.item(0).getData().x will give an error:
AttributeError: 'list' object has no attribute 'x'
kandennti
Hi @rocco.mayr .
Point3D is stored in the ObjectCollection.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        # create points
        pos = [
            [1,2,3],
            [4,5,6],
            [7,8,9],
        points = []
        for p in pos:
            points.append(adsk.core.Point3D.create(p[0],p[1],p[2]))
        # set ObjectCollection
        for p in points:
            segmentPoints.add(p)
        # dump
        for idx, pnt in enumerate(segmentPoints):
            p = adsk.core.Point3D.cast(pnt)
            app.log(f'index[{idx}] - X:{p.x} Y{p.y} Z{p.z}')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
rocco.mayr
That's the line I was looking for, THX
posX = adsk.core.Point3D.cast(segmentPoints.item(0))
