Generate permuted components based on variable parameters
neil_jansenH8DGP
Observer Observer
neil_jansenH8DGP
Observer
Observer
Hi! First time posting, so put this in API and Scripts since it seems like that'd be the place for permutive design.
I want to create N versions of a component, each their own component that I can use together in an assembly in various ways. There are 3 design parameters I'd like to permute with 'n' options for each parameter.
That is:
  1. Shape 1; a1 ... an
  2. Shape 2; b1 ... bn
  3. Hole Size; options d1 ... dn
So I'd end up with (an*bn*dn) unique components that I can then use in various combinations with each other.
Any help pointing towards specific tutorials and such would be greatly appreciated! Thanks 😄
j4n.vokurka
seems like configurations table might be the thing you are looking for. It's relatively new feature so I have just basic knowledge of it but it looks useful. Take a look here:
https://help.autodesk.com/view/fusion360/ENU/?guid=CFG-OVERVIEW
If this is not the way to go for you, you will have to create new components through API.
The difficulty of that process would depend on the type of parameters and complexity of the model but basically the core is the same. Here is a short sample how to create new component:
https://forums.autodesk.com/t5/fusion-api-and-scripts/create-new-component-using-api/td-p/7839368
Hope this was helpful
