Create New Component Using API
isocam
isocam
Can anybody help???
Is it possible, using Fusion 360 API, to capture the "Create New Component" function?
At present, I have to manually input a name for the new component. If the assembly is, for example, 1000 every time I right mouse click "Create New Component", can the part number be the assembly number + 1.
For example,
1000
Part Numbers 1000-001, 1000-002, 1000-003 etc
Many thanks in advance!!!!
Darren
marshaltu
The following sample demonstrates how to create new component and set "name" or "part number" by API.
Marshal
import adsk.core, adsk.fusion, traceback
def run(context):
  ui = None
  try:
    app = adsk.core.Application.get()
    ui  = app.userInterface
    design = adsk.fusion.Design.cast(app.activeProduct)
    root = design.rootComponent
    for i in range(10):
        occ = root.occurrences.addNewComponent(adsk.core.Matrix3D.create())
        occ.component.name = 'My Component{}'.format(i)
  except:
    if ui:
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion Developer
