Fusion crashes when using threading
a.wendler
a.wendler
My add-in runs in the background and receives messages from an external second program. Therefore a thread is created which constantly listens and in the event of a new message runs Fusion360-commands.
Unfortunately Fusion crashes when it has to interact with the UI for example if it has to create a new document.
Here an example:
import adsk.coreadsk.fusionadsk.cammaththreading
def run(context😞
    thread = threading.Thread(target=CreateNewDocument)
    thread.start()
def CreateNewDocument():
    app = adsk.core.Application.get()
    doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
Is there a way to interact with the UI within the thread?
KrisKaplan
You can use a CustomEvent to post a custom event from your background thread, to your main/UI thread custom event handler to perform actions that are limited to the UI thread.
Kris
Kris Kaplan
