Command button won't rename
bevis.hobbs21
bevis.hobbs21
The property to rename a command button in the UI:
CommandDefinition.name
It is documented here: https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-cdf53108-bcaf-418e-b678-f041f2e207c4
And it won't work, when I set it, it doesn't change the name in the UI. The tooltip property changes the name of the tooltip fine, but the name property doesn't change the name of the command button in the UI.
Here's my code:
import adsk.core, adsk.fusion, traceback
button_names = [("Start calc Add-In", "Starts the calculation Add-In."),
                ("Stop calc Add-In", "Stops the calculation Add-In.")]
panel_id = "SolidScriptsAddinsPanel"
command_id = "calc_add_in"
handlers = []; running = False
app = adsk.core.Application.get()
ui = app.userInterface
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
rootComp = design.rootComponent
def msg(message): ui.messageBox(str(message))
class CommandCreatedEventHandlerPanel(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        global running
        try:
            running = not running
            commandDefinitionPanel_.name = button_names[int(running)][0]
            commandDefinitionPanel_.tooltip = button_names[int(running)][1]
            msg("Calculation "+("started" if running else "stopped"))
        except:
            if ui: ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
def run(context):
    global commandDefinitionPanel_
    try:
        workspaces_ = ui.workspaces
        modelingWorkspace_ = workspaces_.itemById("FusionSolidEnvironment")
        toolbarPanels_ = modelingWorkspace_.toolbarPanels
        toolbarPanel_ = toolbarPanels_.itemById(panel_id)
        toolbarControlsPanel_ = toolbarPanel_.controls
        toolbarControlPanel_ = toolbarControlsPanel_.itemById(command_id)
        if not toolbarControlPanel_:
            commandDefinitionPanel_ = ui.commandDefinitions.itemById(command_id)
            if not commandDefinitionPanel_:
                commandDefinitionPanel_ = ui.commandDefinitions.addButtonDefinition(
                    command_id, *button_names[0])
            toolbarControlPanel_ = toolbarControlsPanel_.addCommand(commandDefinitionPanel_)
            toolbarControlPanel_.isVisible = True
            onCommandCreated = CommandCreatedEventHandlerPanel()
            commandDefinitionPanel_.commandCreated.add(onCommandCreated)
            handlers.append(onCommandCreated)
    except:
def commandControlByIdForPanel(id):
    if not id:
        ui.messageBox("commandControl id is not specified")
        return None
    toolbarControls_ = toolbarPanel_.controls
    toolbarControl_ = toolbarControls_.itemById(id)
    return toolbarControl_
def destroy_object(item):
    if item and item.isValid: item.deleteMe()
def stop(context):
    global running
    try:
        running = False
        commandDefinitions_ = ui.commandDefinitions
        commandDefinition_ = commandDefinitions_.itemById(command_id)
        destroy_object(commandDefinition_)
        commandControlPanel_ = commandControlByIdForPanel(command_id)
        destroy_object(commandControlPanel_)
    except:
BrianEkins
This looks like a bug to me.  It appears that setting the name property is working but the displayed name in the panel is not updating.  I could see this because after setting the name and getting the value of the name property after, it is returning the name I set it to.  Also, after setting the name and if I choose the "Pin to Toolbar" option for the command to show the command in the toolbar, I see the new name in the tooltip.
Brian Ekins
thomasa88
"Wait, I already do that in an add-in.."
I loaded your code and I can not for the life of me figure out why it works for my add-in but not yours:
  • Tried moving the update code to the Execute handler (created by the Created handler)
  • Tried setting resourceFolder - but on commandDefinition creation and on update
  • Tried putting the command def under the Utility menu
  • Tried putting the command def under my add-in's menu, and under a sub-menu (Dropdown). The last place is where my add-ins Record button successfully updates! :S
Have not tried:
Making sure the command completes successfully
Letting the event loop run (adsk.doEvents() or a zero delay CustomEvent) - but I can't see my add-in doing that either.
My add-in, for reference: https://github.com/thomasa88/AnyShortcut  AnyShortcut.py is the main file.
I have wrapped the Event handlers quite dramatically, so it's a bit hard to compare.., but they are the add_handler() calls.
You can run the add-in and see that the Record menu item updates when clicked..
Fusion 360 v. 2.0.10253
bevis.hobbs21
I don't appear to be able to access your add-in, could you attach it to this forum? I am eager to see if I can find out why your add-in will rename the command button and mine won't.
thomasa88
That's strange. So you can't access github at all?
I realized that my DirectName add-in behaves more similar to your code and is a bit smaller. It only changes its icon by default, but I patched it to change the name, which worked fine.
I have attached the patched version as a zip.
Patch: https://github.com/thomasa88/DirectName/commit/88c043fdef78a4b5c4dd791df0252fcf44e3ae9b
I tried disabling .isPromoted(ByDefault) in AnyShortcut without any problems. So the promotion does not seem to be part of it.
Edit. @bevis.hobbs21  Are you running Windows or Mac btw? I'm using Windows 10.
Edit. update_enable_button() is the function that changes the text.
