Fusion 360 Python Script - Set Material Name
isocam
isocam
Can anybody help?
Does anybody know how to set the material name using a Python script?
For example only, I want to set the material to "Stainless Steel, Brushed".
Can this be done???
Many thanks in advance!!!!
Darren
kandennti
Hi @isocam .
We have created a sample that applies the material 'Stainless Steel, Brushed'.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        # select body
        msg: str = 'Select Body'
        selFiltter: str = 'Bodies'
        sel: adsk.core.Selection = selectEnt(msg, selFiltter)
        if not sel:
            return
        body: adsk.fusion.BRepBody = sel.entity
        # get Material
        materialLibs: adsk.core.MaterialLibraries = app.materialLibraries
        mateLib: adsk.core.MaterialLibrary = materialLibs.itemByName(
            'Fusion 360 Material Library')
        if not mateLib:
            return
        mate: adsk.core.Material = mateLib.materials.itemByName(
            'Stainless Steel, Brushed')
        if not mate:
            return
        # set Material
        body.material = mate
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def selectEnt(
        msg: str,
        filtterStr: str) -> adsk.core.Selection:
    try:
        app = adsk.core.Application.get()
        sel = ui.selectEntity(msg, filtterStr)
        return sel
    except:
        return None
This will output a list of materials available to you.
import traceback
import adsk.fusion
import adsk.core
def run(context):
    try:
        for mateLib in materialLibs:
            print(f'-- {mateLib.name} : {mateLib.id} --')
            for mate in mateLib.materials:
                print(f'  {mate.name} : {mate.id}')
    except:
        if ui:
