Breaking up code into different code modules within Add-in folder
ebunn3
ebunn3
I'm trying to build an Add-in and don't want all of my code within the same code module.  How does one go about creating additional modules that can be imported into the main module?
Eric
ebunn3
I've figured this out:
It has to do with using Relative Imports.  I used the following import statements successfully to import functions and classes from other modules contained both in the parent folder and sub folders.  I have attached a sample directory of files.
Eric
#Relative Imports
#import module from within same folder
from . import TestScript3_Class as cls3
#import module from sub folder
from .Tests import TestScript2 as ts
from .Tests import TestScript2_Class as cls
#import a specific function from a nested folder (use the dot like a \ in a file path )
from .Tests.TestsCopy.TestScript2 import Test
Eric
