Fusion 360 fails to open VS Code
Due to a plugin not functioning, presumably due to changes in the API, I wanted to fix it myself. However, Fusion 360 fails to open VS Code, instead freezing for a short period, then causing Chrome, if open, to flash as though something had happened, but on inspection, no new tab or prompt was visible in Chrome. I couldn't find anything relevant in the Diagnostics Log. Assistance with this would be appreciated
JeromeBriot
Try this:
  1. Close Fusion 360
  2. Open VS Code
  3. Downgrade the Python extension to version 2019.9.34911
  4. Restart Fusion 360
graham.wideman
I have the same problem, it seems.
In F360: Tools > Scripts and Addins > select a script > Edit
The first time I do this (after starting F360), a command window briefly shows on the screen, and a line or two of commands flash. But the window disappears too quickly to see anything.
Subsequent attempts to invoke Edit seem to do nothing.
I note the suggestion to "Downgrade the Python extension to version 2019.9.34911". How does one do that? I did not find any obvious UI in VSCode to do that.
Thanks.
Nilesh.Mohite
Hi Graham,
First time you see a console window it is related to checking\installng of python extension in vscode.
If you need to downgrade extension to lower version 2019.9.34911.
Please refer to the following similar issue.
API debugger doesn't work after Oct 2019 update
Solutions provided by @goyals will work for you. click here to Go to Solution.
Please let me know if you need more help.
Nilesh Mohite
LinkedIn
If my answer helped you, please use  ACCEPT SOLUTION .
Also be generous with Likes!  Thank you and enjoy!
graham.wideman
Thanks Nilesh, that did the job.
