Forcing Chain Selection of Sketch Elements
Is it possible to force chain selection of sketch elements using SelectionCommandInput? I was not able to find any related filter in Selection Filters. I am looking for something like Chain Selection option in offset sketch UI.
adminTCYL2
Yes, that is what I am looking for as well.
kandennti
@adminTCYL2 .
I gave it a shot.
If I write the result first, it is not well done.
It works correctly when just selecting, but incorrectly when clicking and deselecting the selected items.
# Fusion360API Python script
# -- It does not work correctly. --
import traceback
import adsk.fusion
import adsk.core
_app = None
_ui = None
_handlers = []
_lastSelectEntity = None
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            global _handlers
            cmd = adsk.core.Command.cast(args.command)
            inputs: adsk.core.CommandInputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            onSelect = MySelectHandler()
            cmd.select.add(onSelect)
            _handlers.append(onSelect)
            onInputChanged = MyInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            selIpt: adsk.core.SelectionCommandInput = inputs.addSelectionInput(
                'selIpt',
                'Sketch curves',
                'Sketch curves'
            selIpt.addSelectionFilter('SketchCurves')
            selIpt.setSelectionLimits(0)
            inputs.addBoolValueInput(
                'chainIpt',
                'Chain Selection',
                True,
                True
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            _app.log('Call InputChanged Event')
            eventArgs = adsk.core.InputChangedEventArgs.cast(args)
            if not eventArgs.input.id == 'selIpt':
                return
            ipts: adsk.core.CommandInputs = eventArgs.input.commandInputs
            chainIpt: adsk.core.BoolValueCommandInput = ipts.itemById(
                'chainIpt')
            if not chainIpt.value:
                return
            global _lastSelectEntity
            if not _lastSelectEntity:
                return
            path: adsk.fusion.Path = adsk.fusion.Path.create(
                _lastSelectEntity,
                adsk.fusion.ChainedCurveOptions.tangentChainedCurves)
            selIpt: adsk.core.SelectionCommandInput = eventArgs.input
            selectedEnts = [selIpt.selection(idx).entity.entityToken for idx in range(
                selIpt.selectionCount)]
            pathEnts = [p.entity for p in path]
            [selIpt.addSelection(ent)
             for ent in pathEnts if not ent.entityToken in selectedEnts]
            _app.log('finish InputChanged Event')
        except:
class MySelectHandler(adsk.core.SelectionEventHandler):
    def __init__(self):
        super().__init__()
        _app.log('Call Select Event')
        eventArgs = adsk.core.SelectionEventArgs.cast(args)
        _lastSelectEntity = eventArgs.selection.entity
class MyExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        _app.log('Call Execute Event')
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        _app.log('Call Destroy Event')
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDef = _ui.commandDefinitions.itemById('Test')
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                'Test', 'Test', 'Test')
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
