setting Plane setByOffSet - linking Offset to User Parameter
StephenCim-001
StephenCim-001
Hi All
I have this snip of code.
#read in a User Parmeter
UserStoneFinalHeight = userParams.itemByName('StoneFinalHeight')
#Extract the value of the parmeter
offsetValue = adsk.core.ValueInput.createByReal(UserStoneFinalHeight.value)
#create a offer plane user the value from the parameter
planeInput.setByOffset(xyPlane, offsetValue)
planeStone = planes.add(planeInput)
planeStone.name = 'stone'
planeStone.isLightBulbOn = False
Now this works, but the Offset is not linked to the parameter , so if I change the parameter UserStoneFinalHeight the offset does not update.
With Dimensions , I can link a dimension a parameter with
stoneDim.parameter.expression = 'StoneRadius'  But I can't figure out how to link the offset to a parameter.
Can anyone help 😉
Cheers, Stephen
BrianEkins
You're creating the reference plane by inputting a value.  It just happens that you got that value from an existing parameter but the call to add the reference plane doesn't know where the value came from.
What you need to do instead is pass in the name of the parameter.  Create the ValueInput object like this instead.  This way you're defining an expression that Fusion will use when creating the parameter that drives the offset value.  The expression could be more complex like UserStoneFinalHeight.name + "/2", which would create an expression that is half the value of the UserStoneFinalHeight parameter.
offsetValue = adsk.core.ValueInput.createByString(UserStoneFinalHeight.name)
Brian Ekins
StephenCim-001
Thanks Brian
That worked and I would also like to thank you for the gear script/addin that ships with F360 I refer to it a lot 🙂
Cheers, Stephen
