Fifteen seconds to set a jointMotion limit value via a script using the API??
RogerInHawaii
Message 1 of 1
RogerInHawaii
I have a design that includes some revolute joints. In my C++ script I set the min and max values of some of those revolute joints, with code like this::
MyRevoluteJointMotion->rotationLimits()->minimumValue(GearAngleInRadians);
and it takes FIFTEEN SECONDS to complete that code. Checking the design afterwards shows that it has indeed successfully set the minimumValue as desired.
I can set the actual angle for the joint with code like this:
MyRevoluteJointMotion->rotationValue(AngleInRadians);
and it happens nearly instantaneously, as expected.
Now, these joints reside within Occurrences (i.e. instances) of a Component and not directly within a Component itself. Does that make a difference? Does it take a long time for it to do the setting of the min and max values when it's dealing with joints within an Occurrence?
Basically, why is it taking so long?
Replies (0)
